Old 04-05-2013, 04:30 PM   #1
leo
leo's Avatar
Question Distributor Body Play, What to Do?
I was going over my timing after viewing the YouTube video by Les Andrews and sure enough the first thing I found was that the movement of my spark advance was skewed due to the steering column not being in the correct position. But after that I found that my distributor body did not lock tightly on to the distributor base, seems that I can wobble it back and forth maybe 1/16 - 3/32 of an inch. This must impact my timing when the car is running. The body is a new repro and the distributor base is an original rebuild.
leo is offline   Reply With Quote
Old 04-05-2013, 04:48 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Distributor Body Play, What to Do?
The upper STEEL plate being loose will affect the timing, but the BAKELITE body being loose won't affect the timing. I have seen some loose bodies, but the ones I bought from Bert's, Bratton's, and Little Dearborn have all had a nice snug fit.
Old 04-05-2013, 05:00 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Salutations, "A" Mob, Dog here, we cain't add nothing to T.W.'s conclusions, remember, He's been "playing" with his Model A "parts toys" for a LOOOOONG time! Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 04-05-2013, 05:17 PM   #4
Tom Wesenberg
Hey......I'm not that old!
As fas as tightening the cap, you could run a thin strip of tape around the body. At least this would keep the contacts gaps more even. Wish I knew where the loose caps come from. That's one reason when I find a good part, I try to remeber where I bought it and buy that part from the same dealer again.
