Old 09-17-2018, 09:51 PM   #1
WABOOM
WABOOM's Avatar
Default Gas peddle to throttle linkage 51 Merc
What holds the gas peddle rod to the throttle linkage? Mine has come undone and I haven't had a chance to get all the way under there to take a good look. All I was able to do is hook it back together temporarily.
WABOOM is offline   Reply With Quote
Old 09-17-2018, 10:44 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Gas peddle to throttle linkage 51 Merc
Here's a helpful pictorial from the book shown. Be sure and buy it.
I posted it several times so you can , print, cut and past photos together.
Hope this helps.
Old 09-17-2018, 10:55 PM   #3
WABOOM
WABOOM's Avatar
Thank you. It looks like I am missing # 9825
Old 09-17-2018, 10:58 PM   #4
19Fordy
19Fordy's Avatar
That clip shouldn't be to hard to find as it was used for many years in many cars. in fact there's one on my Snapper lawn mower.
Old 09-18-2018, 08:16 AM   #5
19Fordy
19Fordy's Avatar
Is this the clip?
https://www.summitracing.com/parts/r...yABEgLUF_D_BwE
Old 09-18-2018, 09:38 AM   #6
WABOOM
WABOOM's Avatar
Yes. I ordered it. thank you!
Old 09-18-2018, 09:57 AM   #7
scicala
scicala's Avatar
Have to be careful because they come left and right hand style. The one you need is the opposite side of the one where the throttle rod hooks to the carburetor.
Sal
scicala is offline   Reply With Quote
Old 09-18-2018, 10:04 AM   #8
rotorwrench
rotorwrench's Avatar
There are different sizes too for the diameter of the rod in the application.
Old 09-18-2018, 11:59 AM   #9
WABOOM
WABOOM's Avatar
Sal
Hmm. Hopefully I got the correct part!
Old 09-18-2018, 02:19 PM   #10
Paul Bennett
Napa has them. When replacing my gas pedal, mine popped off the rod. When that happens, you won't find it until you buy another, which I did, both r/h and l/h, buck apiece. Yes, thereupon found the original.
If you go to Napa, take the rod as those clips come in several sizes.
Paul Bennett is offline   Reply With Quote
