Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 06-23-2018, 07:08 PM   #1
barnstuf
Default Used Parts Engine Area
City: Cape Cod
State: MA
Price: in ad
Offering used original parts and I have multiples of each item. Items identified as cores are for restoration, external parts will need cleaning and paint, etc. All prices + postage anywhere in USA.
Connecting rod cores with caps & nuts, $5 each
Timing gear cover, front, 1929-31, $5 each
Timing gear cover, side, $5 each
Intake manifolds, $35 each
Intake & Exhaust manifold combo, $65 set
Water gooseneck on cylinder head 1928-29, $13 each
Water gooseneck on cylinder head, 1930-31, $10 each
Main bearing cap cores, $10 each
B-6344 Main bearing bolt 4 1/2", $2 each
B-6347 Front or Center Main bolt, 6", $2 each
Fan, original, no problem evident yet, $15 each
Starter Drive 1929-31, $10 each
Accelerator linkage, $15 each
Crank ratchet nut, good teeth, $5 each20
Oil pan with tray, 1929-31 $20
Oil pump drive gear assembly, MAY need a new gear, $15
New gear for above, for you to install, $20
Generator cutout, $20
barnstuf is offline   Reply With Quote
