32-48 Drive Shaft Roller Bearing Trust Washer
Guys,
On my 33 Pickup I damaged the front drive shaft roller bearing thrust washer when trying to remove the grease seal in the drive tube. This thrust washer is between the grease seal and roller bearing. I can find no part number for it or references to it in any of my literature. It looks original and has the Ford logo on it. Measures 1-1/4" ID x 1-13/16 OD x .08" Thick. I have checked it against the speedometer gear thrust washer on the opposite side of the roller bearing and the OD's match up but the ID's are different. Thickness looks good as well. Does anyone know where I can find one of these thrust washers and if not, any reason not to put in one that matches the speedometer thrust washer (part # B-17290)?
Thanks Much
