Old 10-31-2017, 01:17 PM   #1
lignell
Default 57 thunderbird
It seems that the overdrive in my thunderbird is not working any thoughts
lignell is offline   Reply With Quote
Old 10-31-2017, 04:37 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: 57 thunderbird
With the cable pushed in does it freewheel when you let off the gas? We need more info to help diagnose it.
Dobie Gillis is offline   Reply With Quote
Old 10-31-2017, 05:53 PM   #3
lignell
yes
Old 10-31-2017, 06:03 PM   #4
Dobie Gillis
OK, that means the freewheeling clutch works. Do you hear the relay and solenoid click when you get over about 28 to 30 mph?
Old 11-01-2017, 06:53 AM   #5
lignell
yes
Old 11-01-2017, 08:00 AM   #6
Dobie Gillis
To confirm the solenoid is functional attach a long jumper wire to the solenoid terminal on the relay with an alligator clip. Touch the other end of the jumper to the battery + post. You should hear the solenoid click underneath the car.
Here's a link to the official Borg Warner operator's/troubleshooting/repair manual. Ignore any reference to a reverse lockout switch, it was deleted early in 1951 in favor of a shift rod inside the transmission that locks out the OD when reverse gear is selected.
http://www.oldcarmanualproject.com/m...rive/index.htm
Old 11-01-2017, 02:29 PM   #7
lignell
thanks for all your assistance
Old 11-01-2017, 02:45 PM   #8
Dobie Gillis
No problem.
