10-10-2017, 10:34 AM | #1 |
Cruise-O-Matic Interchangeability
I have a friend with a 1964 Ford F100 with 292 Y-block and Cruise-O-Matic model PBW-L1 transmission. No modulator and a small cooling plate on the right side of the transmission. Will a Cruise-O-Matic model PCE-AU1 from a Galaxie swap into the F100? The PCE has a modulator and cooling lines that run to the radiator. Wondering about input shaft sizes, tail shaft and torque converter interchangeability.
Patrick |
10-10-2017, 04:46 PM | #2 |
Re: Cruise-O-Matic Interchangeability
http://www.y-blocksforever.com/
Pat This may give you some results, if you don't get all the answers you want |
10-12-2017, 06:20 PM | #3 |
I think the PBW was an earlier design type from the pre 1961 when they were still using mechanical control through the throttle linkage. Most all the pre 61 types were non vacuum controlled. They likely carried over for the Y-blocks in heavy duty applications. I don't know if the bell housings will interchange though. The PCE is a later vacuum modulated model for the heavy duty FE 390 applications in Ford cars. Both are probably medium case cruise-O-matic types but I don't know what all the differences are between the two types. There were long and short tail shafts & housings for the PCE and may also be for the earlier type but this changes the model identifier. I don't have much information for the pickups so most of my info is for cars and I couldn't find much on the PBW type transmission. Later type torque converters can be used on these and I would recommend a change due to parts and conditional concerns.
It definitely won't just be a bolt in. The late 292 might be limited in what will work for it. Soft parts for the cruise-Os are available but the hard parts are getting harder to source every year. I like the Y-blocks but I'm more partial to the FEs so I'd probably go that direction and find a C6 & make it fit but it would certainly be a lot of work. It just depends on how sentimental your friend is about the 64 F100 and the Y-block 292. |
10-13-2017, 10:28 AM | #4 |
Thanks for the info! He’s very sentimental about the truck, but it’s sentimentality on a budget. Kinda cool that he’s 22 and interested in this old iron. I found the PCE Cruise-O-Matic for sale and was hopeful we could drop it in fairly easily. We were quoted $1800-2000 to have the PBW rebuilt, all dependent on hard part failures. We may take it in and see if there are any adjustments that can extend its life.
I’m an FE fan myself with my 1964 Ford Galaxie 500XL Convertible. |
10-30-2017, 09:04 PM | #5 | |
Say no modulator valve but TV controlled? Interesting Read- https://www.ford-trucks.com/forums/1...e-hookups.html
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 10-30-2017 at 09:21 PM. Reason: REDUCE PHOTO SIZE |
11-06-2017, 06:35 PM | #6 | |
11-06-2017, 11:16 PM | #7 | |
Hi, below is a link telling how to adjust the (TV) Throttle Valve cable, if the transmission has one. The TV cable MUST be adjusted correctly. Hope this link works by clicking on it, Or you might have to copy and paste. http://www.yourmechanic.com/article/...pencer-clayton .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
11-07-2017, 08:08 AM | #8 | |
...hmmpf...
I cannot see detail of the cooler asm. Are engine coolant lines plumbed to the cooler asm or is it just hanging in the air as some type of heat exchanger? Quote:
TV- Throttle Valve The later COM will work, but it will be a learning experience as you go through the swap. Most importantly will be the need of a radiator with an oil cooler. BTW- Most truck trans of this period were MX. You would want at the least the larger case COM for light truck uses (IMO).
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
11-09-2017, 07:11 PM | #9 |
I have always heard that the early 55 T-Birds were air cooled automatics, and I have never heard anything bad about that.
11-10-2017, 01:46 AM | #10 | |
It seems the air cooled FOM began changing to coolant cooled in some models (pass. car) during the 1956 model year. It went totally radiator cooled in 1958 with the intro of the COM The FOM was also held over until the 1960 model run I believe for economy models. Light truck seems to have held on longer. One would need the MPC's and TRANS SERVICE MANUAL(s) of the period to figure it out fully.
11-10-2017, 12:21 PM | #11 |
This also has coolant lines flowing to the side mounted heat exchanger.
11-10-2017, 04:17 PM | #12 | |
11-10-2017, 06:06 PM | #13 |
Oh wow, cool pictures! I never saw one of those before.
11-10-2017, 07:13 PM | #14 |
I stand corrected, again...
