Old 01-03-2024, 07:20 PM   #1
Mr. Will
Mr. Will's Avatar
Default electronic voltage regulators (EVR)
I'm looking for someone that does the EVR for my 36 cabriolet. I know I can adjust the 3rd brush but would rather find a EVR if anyone out there is still making them. Any help would be appreciated.
Thanks Dan
Mr. Will is offline   Reply With Quote
Old 01-03-2024, 09:22 PM   #2
terry
Default Re: electronic voltage regulators (EVR)
I assume you want to replace the cutout that sits on top of the generator? There are voltage
regulators made that replace it, but if I'm correct you still have to use the 3rd brush to
to adjust the charging rate. I have a 12v neg ground one never used, but the charging rate has to be put at only about 10 amps if you are using a 6v generator. terry
terry is offline   Reply With Quote
Old 01-04-2024, 07:16 AM   #3
Terry,OH
Terry,OH's Avatar
Fun Projects doesn't make them any more but there was someone who could do the conversion to EVR. A conversion to a diode is still available but doesn't offer regulation.
Old 01-04-2024, 12:32 PM   #4
Mr. Will
Mr. Will's Avatar
Yes looking to replace the cut out with a EVR. Several vendors list them but all are "Out Of Stock".
Just wondered if there was someone here that may be able to help.
Thanks Dan
Old 01-05-2024, 03:39 PM   #5
30Murray
There is a fellow in Alberta who posts on VFF who is making them apparently. They are for Model
A's but may also work on later generators. Just do a search for EVR on that forum.
30Murray is offline   Reply With Quote
Old 01-07-2024, 05:05 PM   #6
tmiller6
tmiller6's Avatar
Recently the MTFCA forum announced that Model T voltage regulators have been redesigned using new components and are available for sale. They are working on 8volt and 12 volt versions and are looking into positive ground versions.
tmiller6 is offline   Reply With Quote
Old 01-10-2024, 01:14 PM   #7
Mr. Will
Mr. Will's Avatar
Sorry, but I'm not familiar with either VFF or MTFCA.
Thanks Dan
Old 01-10-2024, 01:53 PM   #8
Jack E/NJ
Jack E/NJ's Avatar
https://www.vintagefordforum.net/
https://www.mtfca.com/
Jack E/NJ is offline   Reply With Quote
Old 01-10-2024, 03:16 PM   #9
Bob C
For VFF you have to change net to com, this site will not let you link
to VFF.
Bob C is online now   Reply With Quote
Old 01-10-2024, 09:04 PM   #10
30Murray
There is a note on that site's home page that the EVR's are now for sale by "30TUDOR" for $80. I use the same type on my Model A and it works great. Not sure if he has posted here previously.
