04-03-2014, 07:44 PM | #1 |
Camshaft replacement
I just received my new Stipe 340 cam and plan on replacing my worn/pitted camshaft as well as install new modern valves, adjustable tappets and the fiber two piece gear with a metal one. Is there anything special I need to know or do when replacing the old camshaft. I have Les Andrews book and have read through the process. If anyone has any particular advice or experience on the process I'd appreciate it. Thanks in advance.
04-03-2014, 08:09 PM | #2 |
Re: Camshaft replacement
Lube all the moving parts and put assembly grease or Mystik JT-6 High Temp on the cam lobes and cam gear teeth. Be sure the timing marks line up as pictured, as it's easy to be a tooth off with helical gears. Also some book shows the teeth one off.
04-03-2014, 08:13 PM | #3 |
Make sure you use the correct lifters for that cam.
Bob |
04-03-2014, 08:41 PM | #4 |
the correct lifters are the single lock type.
Not sure why you chose the .340 over the .330. Usually need valve/head work to make the best of that. Just installed a .330 in a stock motor for a client. Car drives like a dream and client is thrilled. Bill Stipe specs the lash to be .012 I&E, but i always set an A to .013 for both. Never had ticking Vince Falter has a lot of info on this http://www.fordgarage.com/pages/vincesfords.htm
'31 180A |
04-03-2014, 08:52 PM | #5 | |
04-03-2014, 09:21 PM | #6 |
04-03-2014, 09:44 PM | #7 |
sounds like you are gonna have a nice build !!!
'31 180A |
