Old 09-23-2017, 07:33 PM   #1
stan35
stan35's Avatar
Default Clutch/Tranny problem
My friend has a 1931 Phaeton. While driving the car the other day all was well for awhile. He made a normal stop at an intersection. When he tried to proceed he was unable to put the car into gear. The clutch pedal also felt soft. The gears ground whenever he tried to put it into gear. Had to have the car flatbedded home. While inspecting the car we noticed that the clutch release lever had a crack in it near the pin that holds it on the shaft. Even though it is cracked it appeared to work. At this point our skills ran out. With the car off, it can be shifted through the gears. We tried rocking the car in gear but nothing changed. Would appreciate any advice offered. Thanks, Stan.
stan35 is offline   Reply With Quote
Old 09-23-2017, 07:39 PM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: Clutch/Tranny problem
Just put a new lever on. This happens a lot. Easy fix
Old 09-23-2017, 07:40 PM   #3
Bill G
Bill G's Avatar
Mine did the same thing not long ago, causing the clutch to not disengage. I got my new clutch arm from Bert's, but I replaced pretty much the whole clutch in the process. If the rest of your clutch is ok, then just the arm replacement should not be too hard to do. I did notice that when I bought the new arm, the part listed in the catalog did say that the original part was prone to breaking.
Old 09-23-2017, 07:41 PM   #4
1955cj5
1955cj5's Avatar
That is a common failure.
Replace that release lever and you should be good to go..All the vendors have them...
https://www.brattons.com/clutch-release-shaft-arm.html
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 10-12-2017, 08:34 PM   #5
Trukluvr
I was just reading the thread for some continued learning. I read on the Brattons page that the replacement of the lever could make depressing the pedal 30% easier. Has anyone else used this to make the clutch lever easier to depress? Or point me to a thread about this? Thanks in advance.
Trukluvr is offline   Reply With Quote
Old 10-12-2017, 11:49 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
If the hole to the center of the shaft is 30% longer, then the pedal effort should be 30% less.
