11-10-2021, 02:29 PM | #1 |
Fenton cast iron headers
I've seen some discussion on this recently, but just wanted bring this up and see what if any suggestions. So,.....about 10 years ago I purchased a pair of Fenton headers, either from Flathead Jack or Hot Rod & Custom Supply, both no longer around, for a '51 Tudor, they fit well, and I loved them. Now I'd like another pair, and understand Speedways "Fentons" not so good, they even mention '51 fit "requires grinding" Does anyone make good or accurate offerings of these??
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
11-10-2021, 04:07 PM | #2 |
Re: Fenton cast iron headers
I had some Speedway Fenton's but did not like the fit so I got lucky and sold them. I later found a NOS pair of original Fenton's which are a much better quality. Patric's used to make them but I'm not sure they're still around.
11-10-2021, 06:04 PM | #3 | |
Yep, looks like I'll have to troll for a pair of used or NOS. Patrick's did close up in Nov. 2018 Thanks for the response.
11-10-2021, 06:14 PM | #4 |
>>>about 10 years ago >>>for a '51 Tudor, they fit well, and I loved them. Now I'd like another pair>>>
For the same car? |
11-10-2021, 06:19 PM | #5 |
I wonder if Speedway had to make them a bit different to avoid legal problems or it was just the same old shoddy design/manufacturing process.
The Fenton's on mine have been on for 34 years, and when I changed the engine out 3 years ago, the entire exhaust system was still in great shape. |
11-10-2021, 07:53 PM | #6 |
Alan |
11-10-2021, 09:23 PM | #7 |
According to the 1956 Hot Rod Magazine Article that ran for three months. "How to Build the Really Right Flathead. Headers were not needed unless you built an "All Out " engine.
Supposedly the stock Cast Iron manifolds work well with a Mild engine and dual Exhaust. I have Stock Manifolds on my 40 with 30 year old worn out Steel Pack Mufflers and it sounds Good (to me). Plus I rather spend the $300 for manifolds on Gas or Beer. Just my Opinion |
11-11-2021, 09:00 AM | #8 | |
Not the SAME car, but another '51.
11-11-2021, 10:02 AM | #9 |
IMO, The Fentons exit angles work best running dual exhaust thru the frame.
Give 40fords a shout, he had an original set he offered up. Seem to go for $250-300 out west.
Tim Downtown, Ca |
11-11-2021, 10:26 AM | #10 |
I wish the French flathead manifolds were available. All of the French exhaust I've seen are large diameter cast iron and a true dual exhaust set up without a front cross over pipe.
11-11-2021, 10:36 AM | #11 |
My Opinion only, I think the cast iron absorbs sound, tubes keep the rumble bigger, also my stock 37 manifolds look the most inefficient I ever saw. I used 2” from the center and the 1.5” coming into it from the ends. Got U bends from speedway and made the flanges, not expensive. Don’t know how difficult it would be to make the pipes up in a fender car, I test fit on my car and then bolted pieces to a bare block to finish weld. Could have made them block huggers and go inside frame, probably next time.
11-11-2021, 11:45 AM | #12 |
Tim, if you want, I can take a look in my shelfs, there might be french exhaust parts.
11-11-2021, 01:05 PM | #13 |
11-11-2021, 02:43 PM | #14 |
Ford made a dual exhaust system for the 1953 year. You can buy the LH exhaust manifold from Drake. As noted, the stock system performs as well as headers.
11-11-2021, 02:49 PM | #15 | |
This is interesting and makes sense. I had a '53 motor at one time and it came with those manifolds. I sold them at Hershey. Years later I regretted it when I was trying to fit the exhaust in my hot rod. They sure looked nice. Now I'm on the hunt. Thanks, Tim |
11-11-2021, 09:39 PM | #16 |
Is there a way to distinguish between original and Speedway Fentons? I bought a set about a year ago that a man took off his '40 Ford and the left manifold had a groove ground out to clear the dip stick.
11-11-2021, 10:01 PM | #17 |
Don't the cast iron originals have a tendency to crack? My 52 is fine but the 53 parts car I bought , the cast exhaust manifolds broke on disassembly.
https://www.youtube.com/user/roosty6/videos |
11-11-2021, 10:20 PM | #18 |
On my supposedly NOS Fentons on the left side manifold you can put both bolts in the center flange in from the outside of the manifold. On the Speedways I had the bottom center bolt was awkward to put in as it was behind the manifold.
11-11-2021, 10:33 PM | #19 |
I have what I assume to be repro's from who I dont know, but no problems with bolt holes. However, the dip stick tube was another story. I had to make a curved tube from brake line, screwed into a female fitting in place of the original tube on the pan. Then, the fat ford stick wouldnt go around corners so I made a flexible stick from a wimpy modern dip stick with the flathead handle brazed on to fool you guys. works good
11-11-2021, 11:51 PM | #20 | |
That's the way Patrick used to advise. He was dead set against grinding clearance for the dipstick, likely because too many guys went too deep and destroyed the manifold.
Alan |
