Old 05-09-2023, 06:05 PM   #1
cvicky
cvicky's Avatar
Default Voltage regulator/dual master
there's no marking on my voltage reg
is there a dual master cylinder that will bolt on 54 ford victoria drum brakes
cvicky is offline   Reply With Quote
Old 05-09-2023, 07:28 PM   #2
paul2748
paul2748's Avatar
Default Re: Voltage regulator/dual master
As far as he master cylinder, I hear that people have used a 65-67 Mustang for drum/drum brakes.. I don't know if it's sized right or not. I think it only uses two of the four bolts that are on a 54 - be sure to put bolts in the two empty hole as they hold the brace inside.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-09-2023, 08:35 PM   #3
dmsfrr
dmsfrr's Avatar
What markings are you looking for?
An original may not have been marked 6 volt since there wasn't a 12 volt choice in '54.
Or, if it had a printed label on top it may have faded away.
The terminals might be marked directly on the screw lugs? Example photo...
dmsfrr is offline   Reply With Quote
Old 05-10-2023, 07:28 AM   #4
cvicky
cvicky's Avatar
reg standing up ,terminals on the right , my 55 (12v) is marked at top bat, middle field, bottom arm i assume they're all same (54 has no marking)
my neighbour has 66 mustang drum , i'll check it out
Old 05-10-2023, 08:10 AM   #5
KULTULZ
KULTULZ's Avatar
Question Re: Voltage regulator/dual master
Your 1955 FORD has been converted to 12V ? Am I reading this correctly?
Are you describing a 1954 or 1955 FORD?
Shown is a period decorated 1956/ 12V VR -
Make sure you read the pin-out correctly -
... my neighbour has 66 mustang drum , i'll check it out
Paul is correct. You want the MC he described. It has to be DRUM/DRUM and you need to know if it has internal RESIDUAL PRESSURE VALVES or you have to add external valves.
Is the car manual brakes or power?
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 05-10-2023, 08:59 PM   #6
cvicky
cvicky's Avatar
i think i've located a 65-7 mustang dual master to try
thx
your 56 reg is different then my 55 12v conversion in pics ( question answered: not all leeds are in same location)
my 54 6v with no markings, is still polarized cause i disconected battery and car kept running
thx for the help
next problem- tail lights stay on all the time until i disconected orange doted wire on switch . can i repair switch or is there something else further down the line.
Old 05-11-2023, 12:51 AM   #7
KULTULZ
KULTULZ's Avatar
... next problem- tail lights stay on all the time until i disconected orange doted wire on switch . can i repair switch or is there something else further down the line.
Tail lamps or brake lamps?
Old 05-11-2023, 06:46 AM   #8
cvicky
cvicky's Avatar
tail lights
Old 05-11-2023, 06:48 AM   #9
cvicky
cvicky's Avatar
pic of light switch above with wire disconnected
Old 05-11-2023, 06:49 AM   #10
cvicky
cvicky's Avatar
manual brakes all drum
Old 05-11-2023, 10:36 AM   #11
flatrod
flatrod's Avatar
65/66 Mustangs were still single cylinder masters, you will need to look for 67/68 for dual master cylinders.
flatrod is offline   Reply With Quote
Old 05-11-2023, 06:22 PM   #12
KULTULZ
KULTULZ's Avatar
Arrow Re: Voltage regulator/dual master
thx for the help
Your VR appears to have a decal installed. Those are available for restorations. It (VR) may be aftermarket. Don't worry about polarization as you can do this later.
You are going to need a WIRING SCHEMATIC for the car for both the VR HARNESS and the lighting problem.
Which car is being discussed, a 54 or 55? Do you have shop manuals?
Old 05-11-2023, 07:49 PM   #13
cvicky
cvicky's Avatar
i'm working on canadian 54 victoria flat head original 6 v - no manual
i have manual for my 55 crown
Old 05-11-2023, 07:51 PM   #14
cvicky
cvicky's Avatar
i have friends with 67 -8 mustangs i'll check with them thx
Old 07-15-2023, 08:29 PM   #15
ventport
I put a 67 Mustang master on my 56 T-Bird.
ventport is offline   Reply With Quote
