Old 10-16-2017, 06:12 PM   #1
luvmyclassics
luvmyclassics's Avatar
Default OK to use my crankshaft?
I was planning on using the original crankshaft on my engine rebuild. There was a small chunk missing on an end lobe. The machinest who worked on the engine removed some material to balance the crank. I am not trying to build a high performance engine but do not want any issues either. I have been advised not to use the crankshaft by a couple of hobbyist machine builders.
Need some guidance. Thanks.
luvmyclassics is offline   Reply With Quote
Old 10-16-2017, 06:15 PM   #2
Brian
Brian's Avatar
Default Re: OK to use my crankshaft?
I understand Ford cast their cranks four at a time; they were joined at some lobes. Subsequently separated and roughly fettled. Where they have been separated at the lobes is quite often fairly rough looking. No issues though.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 10-16-2017, 06:36 PM   #3
19Fordy
19Fordy's Avatar
Pictures tell the story.
Old 10-16-2017, 07:16 PM   #4
Capt Kirk
Capt Kirk's Avatar
I'm by no means an expert on flatheads but, in my thinking, you've got an original crankshaft and don't plan on racing. If that's the case, the crankshaft has already proven itself sound with normal operation. If the bearing surfaces are good, or can be made good, I'd use it with no worries. The "chunk missing" that you're talking about has probably been missing for 50+ years and that crank, if good, can probably survive a few more years.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 10-16-2017, 07:41 PM   #5
JSeery
JSeery's Avatar
It's fairly common for Ford cranks to have a chuck or two missing.
Old 10-16-2017, 07:43 PM   #6
flatjack9
flatjack9's Avatar
Missing chunks are the norm. All Ford cranks have them.
Old 10-16-2017, 08:00 PM   #7
Step-down
Step-down's Avatar
My 59 with 8ba crank has a chuck missing and balanced out good ....
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 10-16-2017, 08:11 PM   #8
3twinridges
3twinridges's Avatar
Probably a casting sprue flaw, I wouldn't worry about it if your machinist gave it a thumbs up.
JB
3twinridges is offline   Reply With Quote
Old 10-17-2017, 01:15 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
If it looks anything like this one, it's normal.....run it! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-17-2017, 01:18 PM   #10
luvmyclassics
That picture looks like my crankshaft.
Old 10-17-2017, 01:18 PM   #11
revkev6
those are HORRIBLE and mean you have to replace the crankshaft!
if you are talking to the seller... lol
revkev6 is offline   Reply With Quote
Old 10-17-2017, 08:58 PM   #12
Paul Bennett
Here's min in situ. Engine runs quite smooth. Apprecciate bringing this thread to light as I had some concerns. Even checked the pan for a chunk.
Paul Bennett is offline   Reply With Quote
Old 10-17-2017, 09:03 PM   #13
JSeery
JSeery's Avatar
Meer flesh wound!
Old 10-17-2017, 10:21 PM   #14
Ol' Ron
Ol' Ron's Avatar
Not a problem.If your worried about it, have it nagged. They all kook like that. With one exception, in lhe 52 and in some 53 engines, Ford experimented with a chell molded crankshaft which was used in the 54 and up Y blocks. These are supposed to be much stronger.
