Old 08-07-2014, 09:10 PM   #21
yjwrangler95
Default Re: 1928 Ford Phaeton/Huckster
Thanks everyone, I put the bed on tonight, mounted the grill and the hood. I also mounted the lights back on and put a stone guard on the radiator. I plan on pulling the wheels this weekend and painting them as well as fitting the wood bed back in place.
yjwrangler95 is offline   Reply With Quote
Old 08-09-2014, 10:00 PM   #22
yjwrangler95
Started on the wheels and bumper.
Old 08-10-2014, 05:55 PM   #23
henry's 31
Thanks for sharing your story and your work. I am sure you are motivated by the fact that the A belonged to yor granpa. I admire and enjoy your attention to detail. By sharing your photos you motivate those of us that are working on a family MOdel A.
Please continue to share your photos and work until completion.
Henry's 31
henry's 31 is offline   Reply With Quote
Old 08-11-2014, 09:53 PM   #24
yjwrangler95
Some more pics, worked on the wheels. I'm in the process of nickel plating the headlight rings. Its working but taking forever. I'll post pictures when I get a little further along.
I added chrome lug nuts and polished up the stainless hub covers.
Old 08-12-2014, 09:14 AM   #25
neds29
Very nice story and a nice job. The windshield looks interesting.
Retired civil engineer.
Winters in Phoenix, summers in Ipswich, Mass. and North Dakota.
'29 closed cab pickup- Excellent AZ truck.
'29 roadster- Owned for 21 years but now sold.
'28 CC pickup- My first car in Andover, MA back in '62- '63.
neds29 is offline   Reply With Quote
Old 08-12-2014, 10:15 PM   #26
yjwrangler95
Tried to nickel plate the headlight rings, it kind of worked but not great. I realized the headlight lenses that came on the truck when we got it are wrong, but they don't look bad. I also sat the top on the truck, grandpa made it over 20 years ago. I think it will get a coat of varnish and call it good.
Old 08-12-2014, 10:32 PM   #27
Tom Wesenberg
Tom Wesenberg's Avatar
Do you have a Caswell home plating kit, or how did you try the plating?
I bought the Caswell home plating kit, but haven't set it up to try it yet.
Old 08-13-2014, 07:59 AM   #28
yjwrangler95
I tried to do it myself without buying the Casewell kit. I used vinegar, 99.9% nickel welding rod with the flux removed, salt, and a 6 volt battery charger. It started to work pretty well, but I think i was using to much current or had to much salt in the solution. With more trial and error I think i could get it to work well. I found the "recipe" online. I'm sure the Casewell kit works well.
Old 08-13-2014, 08:21 AM   #29
oldwoodsman
oldwoodsman's Avatar
Nice car and a great story Wrangler. Your Grandpa must be proud of you.
oldwoodsman is offline   Reply With Quote
Old 08-13-2014, 10:26 AM   #30
yjwrangler95
My grandparents came out to the barn together last night and she got teary eyed. They are pretty excited to watch the progress. Hopefully I'll have together in teh next two weeks.
Old 08-13-2014, 08:28 PM   #31
Domino
Domino's Avatar
Send a message via AIM to Domino
Very neat project. I wish that a I had a lift like yours as it sure makes life easier. Keep us post and keep up the good wo
rk.
Domino is offline   Reply With Quote
Old 08-13-2014, 08:31 PM   #32
Domino
Domino's Avatar
Nicw paint job. What brand and type of paint did you use. What do you use in terms of a safety mask or do youmhave a fresh air respirator?
Old 08-13-2014, 09:16 PM   #33
yjwrangler95
The lifts nice, it makes life a lot easier. I've found it makes my buddy's lives easier as well! Its a challenger 10,000 versymetric lift.
I used a base/clear, the brand is Nason and the color is Chrysler Black (PX8). It is one of the deepest black's I've seen. Nason is a cheaper paint but it lays down well and is pretty user friendly.
I also used a Nason high build primer under the paint. It helped hide a lot of the 86 year old patina, but no to much!
I use a cheap zip up suit-$10.00 or so and a head sock, latex gloves and a disposable respirator. The respirator is good for a couple of paint jobs as long as you store it in the zip lock bag it comes in.
I have a large compressor and I use a DeVilbiss Finishline FLG4 HVLP gun with a bunch of different filters.
My "booth" is a 2x4 frame, with some clear home depot plastic. I framed in two large furnace filters and use two fans as my exhaust. It pulls air from inside the building(negative pressure in the booth) through the filters. I also added a couple more lights inside for better visibility.
Thanks for the compliments.
Old 08-18-2014, 09:46 PM   #34
yjwrangler95
I started putting the bed on tonight, grandpa came out to help. He built the bed out of rough sawed oak from a friends woods, and used the handrails out of a convent. It has been built for over 25 years, never installed, and still looks like he just made it. Here are a few pictures.
Old 08-18-2014, 10:02 PM   #35
yjwrangler95
having a hard time with pictures tonight
Old 08-18-2014, 10:32 PM   #36
Tom Wesenberg
It looks good.
Don't look now, but there's a giant eagle's nest on the shelf behind the truck.
Old 08-19-2014, 07:52 AM   #37
yjwrangler95
Originally Posted by Tom Wesenberg View Post
It looks good.
Thanks! My "eagles nest" is a buch of corkscrew willow branches we are going to use for our wedding in December.
Old 08-19-2014, 02:58 PM   #38
Fred K-OR
Fred K-OR's Avatar
Very nice. Great job of putting it together.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 09-02-2014, 10:14 AM   #39
yjwrangler95
Well I took it to town to fill it up with gas, ran great, came back home an picked up Michelle to run some errands and all went well the frist 20 or so miles, then it starting backfiring out of the carb and would not make it back up the hill. Had to put it on the trailer to get it home.
I have a vented gas cap but would it being to tight cause it to vapor lock? I'm going to change the condensor. It would idle perfect but would not run at speed, like it was starving for fuel. Any thoughts?
I think it turned out pretty good though. Still a few more odds and ends to take care of.
Old 09-02-2014, 01:36 PM   #40
KGBnut
KGBnut's Avatar
The first thing I always check when she starts running rough is points. Make sure they are gapped right, and double-check your timing. Both are easy, and quick to adjust.
The project looks great, and the family connection makes it all the better. I got my Model A as a project for me and my father. We have spent more time together in the four years since I got than we had in the previous ten years. The car is great...the time together is better.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
