Old 10-23-2022, 06:41 PM   #1
Keith
Default Bell housing brake & Clutch pedal shaft pin removal
What is the best way to remove the pin that holds the brake and clutch pedal shaft in the bell housing. I am finding it difficult to drive the pin out from the inside of the bell housing using a punch. Cannot get a good blow to it.
thanks Keith
Keith
Keith is offline   Reply With Quote
Old 10-23-2022, 08:50 PM   #2
Tom Endy
Tom Endy's Avatar
Default Re: Bell housing brake & Clutch pedal shaft pin removal
The way I do it, if the bell housing has the earlier dome shape rivet, is to take a chisel and knock the head of the rivet off and then drive the the pin in from the outside.
Tom Endy
Old 10-24-2022, 06:28 AM   #3
Keith
Thanks I'll try that as it does have a dome head shape.
Keith
Keith
