10-06-2019, 12:24 PM | #21 |
Re: ROTELLA 15W 40 Oil
Many reasons for 'black' oil but most over looked is the fact if your driving your Model A without an air filter, sucking up all the turbulent dirt off the highway.
Boat owners have 'clean' oil much longer... |
10-06-2019, 12:44 PM | #22 |
I have an air and oil filter.
10-06-2019, 01:57 PM | #23 | |
10-06-2019, 02:38 PM | #24 |
That's an air filter !! ??
I'd be asking Jim Brierley for suggestions to improve that. |
10-06-2019, 02:40 PM | #25 |
I wouldn't use ROTELLA 15W40 oil even if you paid me.
10-06-2019, 03:35 PM | #26 |
10-06-2019, 04:16 PM | #27 |
Jim Brierley is the performance guru of the Model A having successfully 'run them' at Bonneville.
A stock era Air Maze on a stock Model A has been proven to actually restrict air flow thru a stock A carburetor. From your photo you have a lot of performance breathing going on from headers, trick intake manifold, and a perfectly adequate Stromberg....all to be choked by possibly too small a flowing air cleaner. Just a suggestion.....but excuse me, all this has nothing to do with motor oil. |
10-06-2019, 04:28 PM | #28 | |
10-06-2019, 04:51 PM | #29 |
I have a general note about engine oils.
I do not know how strictly that is regulated in the USA. But in Germany environmental protection has a very high say in the oil mixtures. For example, phosphorus and sulfur must very barely added. However, phosphorus and sulfur are excellent emergency lubricants in the limit lubrication range. (Top dead center cylinder/piston, Outlet-valve stem.) Overall, therefore, discussions are fruitless over then and now, because it did in the past not know better then today. And no lubricant manufacturers is interested today, because the sales volume of vintage oil is uninteresting.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version Last edited by Werner; 10-08-2019 at 01:59 PM. Reason: Correction: NO lubricant manufacturers |
10-07-2019, 08:11 AM | #30 |
I would like to clarify something else:
No A-motor will be damaged if it is driven with "Rotella" for diesel engines. Everyday wear is no different. But with this oil, more will deposit carbon residue and ash than with a similar Shell oil for gasoline engines. The extent to which over the tens of thousands of miles to worse cylinder filling due to coked valves and combustion chambers (worse gas exchange) and perhaps glow-ignitions depends on how the car is driven and whether in the fuel cleaning additives (detergents, MMO) are added. The Rotella oil is undoubtedly a good oil. But for the A, there are more optimal lubricating oils for the same money.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
10-08-2019, 12:02 PM | #31 |
I know very little about air cleaners, I don't run them on my A's, or Bonneville engines. I do know they can be restrictive, and really complicate things when using Strombergs because the bowl vent is below air filter. I live on a dirt road, and my engines show very little wear after many thousands of miles, but still believe they are a good idea.
10-09-2019, 01:38 AM | #32 |
I have used diesel oil for a long time, yes it gets dirty quickly but that is because it's holding the contaminants.
Interestingly it erodes the sludge over a short time. But yuck, clean the sludge out first. Somewhere i had a video of sludge and oil dissolving it but can't think where i left it...
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
10-09-2019, 08:29 AM | #33 |
I find Werner's post #10 interesting. Have a motor that was rebuilt last winter and have been using Rotella 15w40 diesel oil. Motor runs great, but 500 mile oil changes are a deep India ink black color. Have tried 2 different rebuilt carbs, no difference.
After reading the above, get the impression the oil should be in better shape at the 500 mile mark. Do not run an oil/air filter, but now think oil should be in better shape anyway. Am running the hotter W18 spark plugs to keep soot down on the outer part of the plugs, and to keep the black off the center when driving low/medium speeds. Am now wondering if the motor may being running dirty due to the Rotella oil. Think I will try a different non-diesel oil nest year, perhaps Castrol GTX 20w50. What you think? Comments? |
10-09-2019, 10:18 AM | #34 | |
10-09-2019, 11:11 AM | #35 |
Check the gaps at the rotor tip on all contacts in the distributor cap body . A lot of times the gaps will be all over the place in some reproduction distributor caps . Ford recommended a conservative gap of twenty five thousands . For hotter spark at the spark plugs I run a gap of thirty five thousands at the rotor tip . Jumping a wider gap ,to a point will increase the spark intensity . Too much gap will advance the timing to the point that it will run poorly if at all . Running too rich could be the cause of darkening of the motor oil . A hotter spark should help ignite the raw gas .
10-09-2019, 11:38 PM | #36 |
I haven't visited fordbarn for a long time. Decided to see whats up and right there at the top is an oil thread. Nice to see I haven't missed anything
kris |
10-10-2019, 12:38 AM | #37 | |
10-10-2019, 03:00 PM | #38 | |
Yep, it's sad.
10-10-2019, 03:16 PM | #39 | |
The Master Cylinder Enjoying life at the beach in SoCal... |
10-10-2019, 03:19 PM | #40 |
You are correct, same arguments and same misinformation about multi weight oils and how the work.
