02-03-2018, 05:10 PM | #1 |
Tube Valve Stem Size
Does anyone happen to know the thread size for a inner tube valve stem cap? It is finer than 5/16-24. I see McMaster-Carr has 5/16-18, 20, 24, 27, 28, 32, 40 tpi. Not sure why there are so many different sizes in 5/16" threads.
I need to clean up the threads on a couple nickel valve caps. Thanks |
02-03-2018, 06:11 PM | #2 |
Re: Tube Valve Stem Size
Just went to the workshop and measured it for you - 32 tpi.
02-03-2018, 07:47 PM | #3 |
Awesome. Thanks Synchro. I'll order one up. I don't think the local Ace will have that size.
Looking at McMaster-Carr prices, I was hoping it was a 5/16-32 as opposed to a 5/16-28 (or another odd size). They want $8.07 for a 5/32 bottoming tap compared to $23.81 for a 27, 28 or 40! |
02-03-2018, 08:51 PM | #4 | |
32 tpi is probably cheaper exactly because it is so widely used on valve stems.
02-03-2018, 11:03 PM | #5 |
There is a valve stem tool available, it is very handy. I have several one for the shop and one in my roadside tool kit. Clears thread on valve stems
https://www.amazon.com/Pit-Posse-Rem...alve+stem+tool https://www.amazon.com/Valve-Repair-...alve+stem+tool
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
02-04-2018, 02:52 AM | #6 |
I know the voices aren't real but damn they have some good ideas! |
