Old 08-05-2019, 08:07 PM   #181
sharp21
Default Re: First Flathead Build
Moving on!
Getting the pistons separated from the rods. Looks good so far.
Question; reuse the rods or get new?
sharp21 is offline   Reply With Quote
Old 08-05-2019, 08:49 PM   #182
JSeery
JSeery's Avatar
Depends on the condition of the rods. Need to have them checked by the machine shop.
Old 08-06-2019, 06:12 PM   #183
sharp21
Ready to get checked out
Old 08-07-2019, 03:09 AM   #184
Mart
Mart's Avatar
I'd say some of those pistons might be a bit low on compression.
Old 08-09-2019, 01:48 PM   #185
sharp21
Bad news. Machine shop called and says the block is unusable. Lots of cracks with some going into the bores...
Pretty disappointed
Old 08-09-2019, 01:55 PM   #186
Terranova
Boooooo.
That sucks.
Terranova is offline   Reply With Quote
Old 08-09-2019, 02:04 PM   #187
JSeery
JSeery's Avatar
Pretty disappointed
Fairly common but not fun! But you got a lot of experance taking it apart.
Old 08-09-2019, 02:21 PM   #188
leon bee
Sharp: That's just what happened to me, I suspect it must be the usual run of things from what I've read. But there are good blocks out there, I know because I found 4 of em. Start asking car guys wherever you see them.
leon bee is offline   Reply With Quote
Old 08-10-2019, 09:11 AM   #189
sharp21
I did. Got some new tools, learned a thing or two. I really felt I was making progress towards the hot rod I’ve always wanted, but will just need to find something else.
I think I’ll clean up / refurb the parts as best I can then sell them off, then track down another project
Old 08-23-2019, 01:15 PM   #190
sharp21
Got everything back
Definitely some bad cracks
But they cleaned everything else up real nice which is great. Will probably part it all out and sell it to fund the next project.
Thanks all for your help. I had a good time.
Old 08-23-2019, 03:58 PM   #191
JSeery
JSeery's Avatar
The block will make a good mockup tool while you look for a usable one.
Old 08-23-2019, 09:25 PM   #192
RKS.PA
RKS.PA's Avatar
Sharp, how did your machine shop locate the cracks? From your pictures, it's a little hard to see. Since they didn't hot tank or shake and bake it.....might not have worth the expense.....I'm curious how they were able to tell if the cracks were unrepairable.
Probably a stupid question, but consider the source!!
RKS.PA is offline   Reply With Quote
Old 08-23-2019, 09:36 PM   #193
tubman
tubman's Avatar
I agree. I see some rust damage (that is easily overcome), but no fatal cracks (I do see a "Part Number" crack, but they are no problem.) Perhaps a few more pictures of the actual areas of damage would help. Don't give up so easily.
Old 08-23-2019, 09:51 PM   #194
Ol' Ron
Ol' Ron's Avatar
I;d want a second opinion on the cracks. There are some new stop leaks, like Morso's ceramic. I heard of some ne stuff, can't remember the name you can leave in the coolant,
Old 08-24-2019, 06:16 AM   #195
sharp21
They didn’t photograph well but there was one in a port that was unrepairable and another that went from a port straight into the adjacent bore. And a bunch more besides
It was done by mag particle.
Old 03-12-2020, 01:01 AM   #196
Fortunateson
I know this is an oldish thread but you can sleeve the bore and pin the crack.
Fortunateson is offline   Reply With Quote
Old 03-16-2020, 02:38 PM   #197
hardtimes
hardtimes's Avatar
'10 years on a stand, and heads loose'
The old guys often knew what was and wasn't worth their time/money, eh....
Old 03-16-2020, 03:36 PM   #198
RalphM
RalphM's Avatar
Save all the pieces off the block, plugs,caps, breather tube,etc.
Too bad i’m so far away or I’d let you come pick one of mine out. Well if anybody’s making around trip to Alaska let me know.
RalphM is offline   Reply With Quote
