03-09-2021, 01:51 PM | #1 |
exhaust manifolds identification
I have a set of Y-block exhaust manifolds and cross-over that I need help identifying as to fitment. The numbers are EBU-9430-B and EBU-9431-C. They were on a 1954 256 cid Mercury but the Mercury parts manual uses the prefix EBY for 1954 instead of EBU. I am guessing that they may be for a 239 cid, but I cannot translate the U identifier. Help?
03-09-2021, 02:10 PM | #2 |
Re: exhaust manifolds identification
03-09-2021, 02:24 PM | #3 |
ENGINE SERIES IDENTIFIER -
EBU 1954 239CI PASS CAR (DIF) EBV 1954-55 239CI TRUCK ENGINE (CLV) EBY 1954 256CI FORD PI - 1954 MERC - 1954-55 TRUCK (CLV) That ID SYSTEM was used before FORD went to the P&A SYSTEM 1957-58 on where the CASTING ID NOS Prefix were four character,
***** "My 57 A/T Only Has Two Speeds" I had the same problem with a Powerglide ... no matter how hard I tried, I could NOT get that thing to shift into 3rd. - FACETIOUS - FUNK & WAGNALLS - 1: joking or jesting often inappropriately : waggish just being facetious 2: meant to be humorous or funny : not serious a facetious remark |
03-09-2021, 04:37 PM | #4 |
as far as fit goes they will interchange with all y blocks
03-09-2021, 08:46 PM | #5 |
But not necessarily into different vehicles, due to the fit around other parts under the hood.
03-09-2021, 09:35 PM | #6 |
03-10-2021, 12:45 PM | #7 |
Thanks for all of the comments. I can now be fairly certain to market them as 1954 Ford 239 while still fitting a 256, 272, and 292, depending on which heads match with the size of openings.
