02-06-2018, 07:36 PM | #1 |
The Hood
Sandblasted the hood and sprayed 1 coat of the etch primer, and two coats of the high build primer, due to the cold weather I think its better to do the rest of the work when its warmer outside. The fumes of that paint is just too strong for the garage under the house.
02-06-2018, 07:52 PM | #2 |
Re: The Hood
Car looks great. Don’t blow your house up, wait till spring to finish. Enjoy.
02-06-2018, 08:11 PM | #3 |
Re: The Hood
Just be aware that some two component paints require a temperature above 50 degrees to fully activate. You might be rushing the season.....and wasting your $$.
02-06-2018, 08:16 PM | #4 |
Re: The Hood
02-06-2018, 08:22 PM | #5 |
Re: The Hood
Patience is a virtue. The car is looking good. Jeff
Let's let pylons, be pylons! |
03-23-2019, 08:03 PM | #6 |
Re: The Hood
03-24-2019, 08:48 AM | #7 |
Re: The Hood
I'm using nason 2K ful-thane with activator and slow reducer, it contains cyanide, I wear a respirator, long sleeve shirt and nitrile gloves, 65*or above, your car looks good.
carry on |
