11-11-2014, 09:14 PM | #1 |
Ford Big Truck 2-speed rear axle nut size
Ford Barners,
I'm in the process of overhauling the brakes on my 47 COE truck. It is equipped with the stock 2-speed axle. To get to the rear assemblies, I need to remove the axles and hub/drum off of the axle housing. I haven't removed the axles yet so I haven't been able to answer part of these questions myself. However, I do know I don't have a wrench/socket large enough to loosen the axle locknut. This is Ford part no. 4252 on the diagram. Questions: 1) what is the nut size? 2) is it hexagonal or octagonal? 3) does anyone manufacture a wrench/socket to fit this nut? Any help would be appreciated. Dan |
11-11-2014, 09:53 PM | #2 |
Re: Ford Big Truck 2-speed rear axle nut size
Don't know the nut size but there is a wrench to fit. Came with the truck. It's thin steel with a slot for a handle. Got a similar aftermarket one hanging up somewhere. Don't need anyway. Just use a six inch or so cold chisel with a small ball peen hammer as motive force to remove and tighten. All the nuts I ever saw had the scars of other guys that didn't have the tool including my 39 Dump truck. I used a chisel and it worked fine.
ML |
11-13-2014, 03:49 AM | #3 |
Very true. Most of the people who worked on those never had the wrench, and I've seen very few nuts that didn't have chisel or punch marks.
11-13-2014, 12:57 PM | #4 |
Thanks much.
I was able to get a 2-3/8ths inch octagonal socket for the front hub caps. I still haven't found reference to the size of the rear although I suspect it is also 2-3/8ths but it may be hexagonal. I'll find out this weekend when I get into it. |
11-13-2014, 10:04 PM | #5 |
Dan, be interesting to know the size. I could take one apart but it's a little cold. The socket I have is 3 and 1/4 X 3 and 7/8ths octagon. Part number is 3256E5 which i'm thinking may be an Eaton number. Fellow I bought it from had lots of Ford parts for sale at a flea market and thought it might fit. What the heck, it was only five bucks. Looks nice hanging on the wall.
Let us know. ML |
11-14-2014, 11:50 AM | #6 |
Bob |
