Old 02-16-2024, 06:05 PM   #1
fifty-one f-1
Default flathead camshaft covers
I have two flathead camshaft gear covers. It is going into an 8BA motor. I am to the point on my rebuild to install the cover over the gears. I am using a Mercury 8cm cam. They look similar except one is a thicker cover. Is there an advantage to using either cover? Maybe I am over thinking this and I can use either cover. I assume the thicker cover is the correct cover because it has part number for a Mercury car 1cm 6653 that would match the cam? I did not take the motor apart, but I am finishing the project. Really appreciate the help.camshaft gear cover 1.jpg
fifty-one f-1 is offline   Reply With Quote
Old 02-16-2024, 06:07 PM   #2
petehoovie
petehoovie's Avatar
Default Re: flathead camshaft covers
Originally Posted by fifty-one f-1 View Post
I have two flathead camshaft gear covers. It is going into an 8BA motor. I am to the point on my rebuild to install the cover over the gears. I am using a Mercury 8cm cam. They look similar except one is a thicker cover. Is there an advantage to using either cover? Maybe I am over thinking this and I can use either cover. I assume the thicker cover is the correct cover because it has part number for a Mercury car 1cm 6653 that would match the cam? I did not take the motor apart, but I am finishing the project. Really appreciate the help.Attachment 536600
Attachment 536601
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 02-16-2024, 06:21 PM   #3
19Fordy
19Fordy's Avatar
Use the merc oil cover since you have it. I have found that 8BA's use the stamped steel cover while Merc use the cast cover. Don't know why?
Old 02-16-2024, 06:54 PM   #4
petehoovie
petehoovie's Avatar
Old 02-16-2024, 07:21 PM   #5
Angledrive
Angledrive's Avatar
Don't forget the oil galley plug
Angledrive is offline   Reply With Quote
Old 02-16-2024, 09:19 PM   #6
Jack E/NJ
Jack E/NJ's Avatar
Stampings deform easier than castings. Castings crack easier than stampings, Which feature do you prefer? .
Jack E/NJ is offline   Reply With Quote
Old 02-16-2024, 09:36 PM   #7
mcgarrett
While you're working in this area of the engine, don't forget to check/replace the idler gear bushing. I overlooked this while doing a rebuild and my engine sounded like a rod knock. Replaced the idler bushing and all was right with the world again!
mcgarrett is offline   Reply With Quote
Old 02-17-2024, 05:52 AM   #8
19Fordy
19Fordy's Avatar
mcgarrett: Thanks for posting that piece of info about idler gear bushing.
I was not aware of that malady.
Old 02-17-2024, 08:49 AM   #9
pistonbroke
Now this is interesting . The 53 mercury 255 I just assembled has a boss in the cast cover to give the idler gear shaft support on the outer end. I wonder when and why that happened? Tim
pistonbroke is offline   Reply With Quote
Old 02-17-2024, 11:48 AM   #10
Ken/Alabama
Ken/Alabama's Avatar
Also keep in mind that on the 8BA it’s possible to install the idler gear backwards. If it’s backwards it will not engage the oil pump. Just something to watch out for.
Ken/Alabama is offline   Reply With Quote
Old 02-17-2024, 12:07 PM   #11
fifty-one f-1
Thanks for all the reply's. Angledrive I did already install my plug on the front of my motor thanks for the reminder. Mcgarrett I think I will replace the bushing seems like cheap insurance. Ken I have a book that shows the correct install, thanks.
Old 02-17-2024, 09:08 PM   #12
mcgarrett
After pulling my engine TWICE trying to find the source of the knocking noise in a new rebuild, I was discussing the problem with an old time flathead hobbyist and he asked if I checked the bushing. When I took the drive/idler cover off I noticed the idler gear was wobbly and loose. I installed a new bushing and put it back together. Once the engine was back in I held my breath and cranked it up. Noise was gone!! I had simply overlooked paying proper attention to that important part of the engine.
Old 02-18-2024, 08:36 AM   #13
Desoto291Hemi
I have an 8CM,,,,1949 Mercury engine,,,,,,mine came with the stamped cover .
My engine seemed to never been apart,,,other than having a valve job done to it .
The insides were in excellent condition and only needs a slight bore to clean up the cylinders .
Desoto291Hemi is offline   Reply With Quote
Old 02-19-2024, 05:32 PM   #14
Pete
Pete's Avatar
I prefer a 1/4 inch thick flat steel plate for the above reasons although we do not use the idler gear and shaft and rear cam gear. (dry sump)
