03-20-2011, 02:50 AM | #1 |
Rear window wood in my 28 Tudor
Can anyone provide a bit of advice about fitting the rear window and wood please. In particular, the four small corner blocks that are nailed into the main wood frame. How do I correctly locate them? They seem to act as support for the glass? Is it safe to fit the glass after painting the body? Thanks.
Gus |
03-25-2011, 02:55 PM | #2 |
Re: Rear window wood in my 28 Tudor
btt
03-25-2011, 03:56 PM | #3 |
These are the only 2 pictures I have of the rear window in my unrestored 2-23-29 Tudor. If they don't help, I can't get to the car for several weeks yet. |
03-25-2011, 08:12 PM | #4 |
The corner blocks give support to the window seal. I made new blocks for mine and epoxied them in place rather than using nails. The originals that I removed had split from the nails and were loose. I believe it is better to install the glass after painting. Gar Williams
03-27-2019, 07:19 PM | #5 |
Just got a new Snyder's catalog today and they are selling the corner blocks made out of Delron (sic) also known as Delrin; $10.75 ea. They say originals were made of Bakelite so I am not sure how they were fastened.
03-28-2019, 11:41 AM | #6 |
03-28-2019, 09:19 PM | #7 |
I have a 1930 Tudor and I have never seen any corner blocks in the original body before I started my restoration. Did the 30-31 Tudors have the same blocks as the 28-29? Thanks for your answer. Grant
03-29-2019, 04:45 PM | #8 |
My 30 Tudor has em.
