Old 11-10-2019, 10:42 AM   #1
shew01
shew01's Avatar
Default Is there such a thing as a 6 volt heater?
Is there such a thing as a 6 volt heater that could be used in a Model A? I’d rather not cut a hole through the firewall for a manifold heater.
Old 11-10-2019, 10:47 AM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Is there such a thing as a 6 volt heater?
Vendors stock 6v or 12v hot water heaters. 6v was all that was available for many years.
Tacoma Bob is offline   Reply With Quote
Old 11-10-2019, 10:48 AM   #3
Chuck Dempsey
Chuck Dempsey's Avatar
Here is a thread about 'though the floorboard' vents.... https://www.fordbarn.com/forum/showt...orboard+heater
Chuck Dempsey is offline   Reply With Quote
Old 11-10-2019, 01:20 PM   #4
Charlie Stephens
If you are asking about a heater where 6 volts is used to run the fan and hot water to provide the heat the answer is yes. If you mean 6 volts to supply the heat the answer is probably no and if you found one you would have to have a very output electrical system to supply the current. I would suggest running the hoses through the floor and using a period correct hot water heater.
Charlie Stephens
Old 11-10-2019, 02:19 PM   #5
burner31
burner31's Avatar
Much easier to install...
Mine is high voltage...but that's OK
Keith
Shawnee OK
'31 SW 160-B
Old 11-10-2019, 03:28 PM   #6
shew01
shew01's Avatar
Charlie Stephens
Yes, this is what I was asking. I figured heat output would be low. Otherwise, I would have some sometime advertised on the web.
How difficult would it be to install a hot water heater with a 6 volt fan? Is it a huge hassle that invites brand new problems to be fixed? The hot water heats I’ve found seem to be larger than what I anticipated. Where should they be placed in the car? Behind the stick shift?
Old 11-10-2019, 03:29 PM   #7
shew01
shew01's Avatar
Lol. My wife got a chuckle out of that. :-)
Old 11-10-2019, 03:31 PM   #8
shew01
shew01's Avatar
Spelling
Otherwise I would have seen something advertised on the web.
Old 11-10-2019, 08:05 PM   #9
mleder
This summer in preparation for the Great Northern Tour of the Twin Cities Model A Ford Club in October I installed a Zirgo Gobi heater on my car. Around $90.00 and found on eBay sites. Well built and compact. Hose and fittings and valves will cost you maybe another $90.00?. No holes cut and it gave great heat in the cold damp days we toured, mornings were mid 30 degrees and wet . I now would not be without it. Although my car is 12 volts and a four door sedan there is no reason why it shouldn't run on six volts at a reduced fan speed. It has three speeds and the high speed is powerful. You might try to find a 12 volt DC motor out of an old heater at a U pull it yard and just see how much speed difference you get between the two voltages and if you think it is not too bad install a unit like this.
mleder is offline   Reply With Quote
Old 11-11-2019, 04:04 AM   #10
woofa.express
woofa.express's Avatar
Simply remove a floor board. It works well, the modification is simple and easy to rectify if and when required.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 11-11-2019, 04:33 PM   #11
Tinbasher
Tinbasher's Avatar
Vintage Air has a nice little heater with a fan but it's 12 volts. You may want to check with them and see if they have a 6volt unit. The heaters about 8"X6"X8" long.
Tinbasher is offline   Reply With Quote
Old 11-11-2019, 07:36 PM   #12
OLDMANKOHOUT
https://www.vintageford.com/sect_sea...ategory=Heater
https://www.vintageford.com/word_sea...w=21&PageNum=2
OLDMANKOHOUT is offline   Reply With Quote
Old 11-12-2019, 09:30 AM   #13
DD931
DD931's Avatar
If you are going to run a hot water heater I suggest that you use a 180 degree thermostat.
DD931 is offline   Reply With Quote
Old 11-12-2019, 10:25 AM   #14
Corley
Get a under the seat hot water heater from an old car. They are only about 2" tall, and throw plenty of heat.
Corley
Subscribed to the KISS principle!
Corley is offline   Reply With Quote
Old 11-12-2019, 01:54 PM   #15
Ak Sourdough
Ak Sourdough's Avatar
https://www.ebay.com/sch/i.html?_fro...odkw=6v+heater
Ak Sourdough is offline   Reply With Quote
