Old 05-20-2019, 06:41 PM   #1
philipswanson
Default King Pin Cross Pins
Do you guys run into king pin cross pins that are super hard to remove? On my 40, I have been beating the cross pin for a while but on the passenger side it doesn't budge. On the drivers side it came out with a few light taps. Should I put heat on it or just keep pounding or ???
philipswanson is offline   Reply With Quote
Old 05-20-2019, 06:46 PM   #2
skidmarks
skidmarks's Avatar
Default Re: King Pin Cross Pins
New king pin kits includes new keeper bolts. But keep your original long acorn nuts. They also act as stops. The new Kits have regular nuts.
A good square hit usually knocks them out
skidmarks is offline   Reply With Quote
Old 05-20-2019, 08:57 PM   #3
philipswanson
Got it. Just took allot of pounding. About 100 hard blows! Thanks.
Old 05-20-2019, 09:08 PM   #4
Pete
Pete's Avatar
Can we assume you were pounding on the slightly backed off stop nut rather than the threaded end?
Old 05-20-2019, 09:15 PM   #5
RalphM
RalphM's Avatar
I have had those be stubborn enough to require drilling out, I drill increasing size till it’s almost full diameter. Not too deep though, only through the threaded portion, enough to be a tad into the axle hole, then use a good punch.
RalphM is offline   Reply With Quote
Old 05-20-2019, 11:00 PM   #6
Tinker
Tinker's Avatar
Can't say I've ever had issues with those. They are tapered but there is very little load or force on them. Spray some PB or Kroll and walk away for a bit, repeat as needed. As mentioned back the nut off and hit it. Same with going gorilla on any threaded ends.
For sure keep the original nut ends, they act as stops as mentioned. They are not reproduced. (to my knowledge)
Old 05-21-2019, 06:17 AM   #7
Mart
Mart's Avatar
Never had one that wouldn't come out. The original nut, backed off just a bit and a good well aimed and angled blow and that's normally enough for me.
Mart.
Old 05-21-2019, 10:35 AM   #8
19Fordy
19Fordy's Avatar
Are they are easier to remove if front wheel is off the ground?
Old 05-21-2019, 10:53 AM   #9
philipswanson
Only a front axle still attached.
