07-13-2017, 03:26 PM | #1 |
Snyder's High Compression Heads
Hi, I have a 1932 C Head in my A. Advantages/Disadvantages of converting to a 5.5 or 6.1 ? I have a T5 transmission with a 3.78 rear end. Thank you for any input ! Gary
07-13-2017, 04:24 PM | #2 |
Re: Snyder's High Compression Heads
The Model B compression ratio was 4.6 : 1. The Snyders Heads will give a noticeable increase in torque but you will have to switch to the Model A water pump and less spark advance should be used to avoid detonation.
07-13-2017, 04:27 PM | #3 | |
What shape is your engine in ? The two Snyder cr that you mention , IMO, will give you something to smile about , performance wise. That is unless you have a worn out / rattle engine, then might make it more rattle. At this time, I'm running a Snyder 6:1 and my B engine likes it ! However, my B is built to handle most any head and I just took off one of Tod's cast iron crow foot flatheads...at 8:1. Can't help myself. Have to continually experiment, kind of what you are doing ! |
07-13-2017, 04:43 PM | #4 |
How does this increased compression and torque affect the Babbitt bearings
07-13-2017, 05:46 PM | #5 |
07-13-2017, 08:12 PM | #6 |
07-13-2017, 08:28 PM | #7 |
Just don't make the engine work too hard at low revs.If you hear detonation, your're doing it damage. Other than that, I say "Go for it".
07-13-2017, 08:34 PM | #8 |
By the way the "C" is just a parts number designation, not a Model. Also it does not mean the crank is counter balanced, it might be but then again there is a better chance that it's not.
07-13-2017, 08:41 PM | #9 |
Frank: I've been told that 7 or a little above is about the top end compression wise for a stock A in good shape. The key is not to advance the timing to far.
07-13-2017, 09:57 PM | #10 |
Is the FS Zipper ignition and 5.5 head a good combo, re: automatic advance vs. manual spark control?
07-13-2017, 10:34 PM | #11 |
Howdy boys, I haven't posted on here since it was new, back in 2010ish. So, here goes. I have a 5.5 on my pickup, that I shaved .075 off of. Really made a difference. I have a counter balanced crank, lightened flywheel, and FS Zipper ignition installed in the engine, along with a BW OD, and 3.78's. (The engine outran the 4.11's I had in it, so I installed the 3.78's) 65 MPH is easily obtained, but I don't go there, other than to show off. Great combo in my opinion.
07-13-2017, 10:36 PM | #12 |
One more thing, just be careful not to shave off too much of the head surface! Do some measuring on your block and piston rise, so you don't end up with an expensive mistake! Questions? Thanks!
07-13-2017, 11:18 PM | #13 |
I have an old cast iron 5.5 head on my car. I haven't done anything to reduce the spark advance and I haven't noticed and pinging. Is this something I should be worried about?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
07-13-2017, 11:29 PM | #14 | |
07-14-2017, 05:27 AM | #15 |
I'm running the 6.0 head and a lightweight flywheel on my 30 pickup. You don't need much timing and she scoots right along. I'll be picking up another 6.0 at Hershey!
07-14-2017, 12:18 PM | #16 |
That's what I have and it's working great.
07-14-2017, 12:59 PM | #17 |
Thank you all !! Very helpful !! Gary
