07-04-2010, 06:14 PM | #1 |
1940 banjo axel nut torque?
I seem to be unable to find the axel nut torque for the nut does anyone know what it is?
07-04-2010, 06:19 PM | #2 |
Re: 1940 banjo axel nut torque?
200 to 212 ft lbs
07-04-2010, 07:09 PM | #3 |
Thanks
07-04-2010, 08:27 PM | #4 |
I will look in my Ford Manuals at my shop in the morning BUT I think it may be closer to 100-125 #ft.
I may be wrong BUT I do not think the axles and nuts will stand 212 #ft. I go real tight with a 1/2 in. breaker bar and then go a little more until I can install a cotter key. I usually will tighten them again after I have driven the car several miles and then install the cotter key. Leave the hub caps off untill the cotter key is in place. Again, Just my opinion. Chris |
07-04-2010, 09:32 PM | #5 | |
The final direction on tightening axle nuts reads: "tighten nut 356074-S to 200 to 220 foot pounds; then continue tightening to the next castellation providing final resultant torque does not exceed 275 foot pounds."
07-05-2010, 10:23 AM | #6 |
All of my V-8 informatiion is at my shop and I was going from the information I had here at home. Model A Ford instructions are fro 125 # ft. Sense they use the same size threads as the later axles, I was thinking the later V-8s would be something simular. If Ford says to torque to 200-220 # ft then that is what I would do. Chris |
07-05-2010, 01:12 PM | #7 |
