Old 05-20-2011, 01:51 PM   #1
jack in san diego
Default 1948 Ford firing order
GHi Fellas: I had a misfiring ignition, took it all down. I can't remember the firing order so I can trace my wiring. HELP Please, thanks, Jack
jack in san diego is offline   Reply With Quote
Old 05-20-2011, 02:00 PM   #2
Mike in AZ
Mike in AZ's Avatar
Default Re: 1948 Ford firing order
plenty of info on MacVP's website....link is to one page...hope it helps....Mike
http://www.vanpeltsales.com/FH_web/f...48_221-239.htm
Mike in AZ is offline   Reply With Quote
Old 05-20-2011, 03:55 PM   #3
ford1
1 5 4 8 6 3 7 2, cylinders # 1 2 3 4 from the front to the back on the passenger side 5 6 7 8 on drivers side front to back
ford1 is offline   Reply With Quote
Old 05-20-2011, 10:03 PM   #4
jack in san diego
Thanks guys: I spent about 3 hours putting it back together today and I see now that I mistook 1-2-3-4 on drivers side. So I did it all wrong no wonder it wouldn't run and kept backfiring back through the carburetor. Will try again tomorrow. Thanks for the info. Jack
Old 05-20-2011, 11:28 PM   #5
Mike in AZ
Mike in AZ's Avatar
ouch....what carb are you running??...backfires can damage the 94 type carbs, i think.....Mike
