09-30-2019, 01:02 PM | #21 |
Re: Fan oil
That is the one I'm referring to. Fan is listed under the items that use engine oil as a lubricant. I would assume they are just using a general statement that is not specific to the model year diagram. But wasn't positive it was a 40 diagram!
Just noticed it also list brake clevis pins! The only "C" I can locate on the diagram it's self is for the distributor and generator. This may or may not be a 40 diagram based on other post. Last edited by JSeery; 09-30-2019 at 03:33 PM. |
09-30-2019, 01:19 PM | #22 |
Re: Fan oil
09-30-2019, 03:25 PM | #23 | |
Re: Fan oil
Looking close at the chart that Adileo posted, it has an arrow pointing to the fan hub that indicates "V" and I think "B". At the bottom of the chart, "V" says to remove plug and add 1oz of Hypoid Gear Oil. No mention of motor oil. If you have a reproduction manual, they may have used that one lube cart to be included on all the early Ford manuals that they reproduce regardless of the year. Some one must have a book of the service bulletin's that will show when Ford changed to gear oil from motor oil to lube the hub. |
09-30-2019, 03:32 PM | #24 |
Re: Fan oil
Very interesting, now I wonder what year that chart is for????
09-30-2019, 04:11 PM | #25 |
Re: Fan oil
My chart?
Thanks Andy 1952 F1 |
09-30-2019, 04:15 PM | #26 |
Re: Fan oil
09-30-2019, 04:36 PM | #27 |
Re: Fan oil
I think the fans that take oil are for '42-'48 cars and '42-'52 trucks. Somebody on this site should know for sure. I'm just going from memory.
09-30-2019, 04:41 PM | #28 | |
Re: Fan oil
09-30-2019, 04:51 PM | #29 |
Re: Fan oil
Not being one to play on the “stock” side of the fence, I use Slick 50 .....
09-30-2019, 05:49 PM | #30 |
Re: Fan oil
Curious cars 42-48 would that be EAB? Reason I ask is my 39 has EAB heads and based on pencil test, I thought, I had a later model engine. However, my fan does not have a place for oil.
09-30-2019, 08:50 PM | #31 |
Re: Fan oil
There could be any mixture of parts on the engine. Where is the fan mounted and how is it driven (belt wise)? Ford used a lot of different fan arrangements.
10-01-2019, 05:12 AM | #32 |
Re: Fan oil
Fan is on crank - one belt drives pumps and fan. It’s not a big deal estout just got me thinking..I’m pretty sure it’s a EAB but..as long as it runs well and gets me where I wanna go and back, I’m happy
Thanks Andy 1952 F1 Last edited by adileo; 10-01-2019 at 06:40 AM. |
