Old 08-16-2020, 06:34 PM   #1
philipswanson
Default Removing Windshield On a '51 Wagon
I am getting my shoebox woody ready for paint. The old rubber around the windshields is hard. Not saving the rubber or glass. What procedure do you recommend? I have the inside garnish rails off and have run a plastic wedge tool around the circumference but the glass is cracked but not coming out. What is the easiest way to pop it out? Anybody know? Thanks.
philipswanson is offline   Reply With Quote
Old 08-16-2020, 06:46 PM   #2
paul2748
paul2748's Avatar
Default Re: Removing Windshield On a '51 Wagon
Take a knife or other sharp bladed instrument and cut the rubber, going around the glass seeing how your not saving anything.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-16-2020, 10:06 PM   #3
philipswanson
Rubber is too tough to cut. Used a linoleum razor knife and still too tough to cut. I did weaken it somewhat. Broke out the drivers side with a rubber mallet. Made a big mess but got it out. Will do other side tomorrow. Thanks.
Old 08-17-2020, 08:30 AM   #4
TJ
TJ's Avatar
A box cutting knife has always worked for me.
Old 08-17-2020, 09:38 AM   #5
philipswanson
Ended up just busting the windows out, then removing the rubber. Big mess but works. Couldn't cut that old brittle rubber much.
