08-01-2020, 08:03 AM | #1 |
Fallow up on balance beads
Sometime ago I posted a question on how effective balance were in model A tires. Several of you responded and some asked for a fallow up. I finally got around to putting them in. Kind of a slow process getting them down the valve stems, about 15 minutes a tire. I used some old hair clippers to help vibrate the stems and that helped. Before I installed the balance beads, my front fenders would vibrate some at road speed. After I put the beads in there is no bounce or vibration. In my case the beads made a significant difference.
08-01-2020, 09:23 AM | #2 | |
Re: Fallow up on balance beads
Using the clippers was a good idea. I used my tool engraver the vibrate the stem.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 08-01-2020 at 06:46 PM. |
08-01-2020, 09:50 AM | #3 |
I had gone into a local tire shop for balance beads for another vehicle and he recommended a green liquid balancing material. Can't use it with pressure sensors but my "A" came out before they were a thing (LOL). Said that the liquid trans the rubber and helps it last longer. Don't know if that is true but it was 1/4 the $ of the beads.Was easy to put in (used a syringe) and works very well. It's called "Tire Life".
08-01-2020, 10:03 AM | #4 |
I took my wheels to a local garage that has a spin balancer with the correct adapter to take my 21" wheels. He put the stick on weights where needed and I painted them wheel color. That was in 2014 and they are still good to go. I had beads in my Model T and never thought they worked well.
08-01-2020, 12:10 PM | #5 |
Drove my 29 AA truck for years with no issues with tire balancing. Of course my cruising speed was just shy of 30 mph. This last winter I put in a Warford overdrive and with the increase in speed I began to experience problems. I put in Dyna Beads and they smoothed things out straight away.
Dave / Lincoln Nebraska |
08-01-2020, 01:49 PM | #6 |
08-01-2020, 05:07 PM | #7 |
08-01-2020, 05:23 PM | #8 | |
Hair clippers. What a novel idea. Good job. Sent from my iPhone using Tapatalk |
08-01-2020, 05:24 PM | #9 | |
Tool engraver. That’s a good idea too. Sent from my iPhone using Tapatalk |
08-01-2020, 06:11 PM | #10 |
Is anybody else wondering what the wife might have that vibrates???
08-01-2020, 06:49 PM | #11 |
A mixer??
The Master Cylinder Enjoying life at the beach in SoCal... |
08-01-2020, 06:50 PM | #12 |
I slipped about 12” of 1/4” clear vinyl tubing over the valve stem, filled it with beads using small funnel and then vibrated it with a Craftsman vibrating tool without a tool in it. It filled the inner tube quickly.
08-01-2020, 09:18 PM | #13 | |
Do you have metal valve stems, or do you have rubber valve stems? Sent from my iPhone using Tapatalk |
08-02-2020, 11:57 AM | #14 |
It has been my experience that unbalanced Model "A" wheels start to tamp the road at about 55MPH.
Bob Bidonde |
08-02-2020, 03:23 PM | #15 |
I recall a posting that described the addition of a certain volume of antifreeze into the tube, with the same result as the use of Dynabeads. I have lost track of the posting.
08-02-2020, 07:53 PM | #16 |
The nice thing regarding dynabeads, is they balance the drum as well, while a balanced tire/wheel could still have balance issues if the drum isn’t perfectly balanced. Don’t know if that is a viable concern or not, but it’s a consideration.
