10-17-2019, 08:11 AM | #1 |
flathead engine 1941
what years of flathead bolt right in?
what are mods necessary to make other years to fit 41? thank you. |
10-17-2019, 08:19 AM | #2 |
Re: flathead engine 1941
http://www.vanpeltsales.com/FH_web/f...ifications.htm
See above 38-48 will bolt in using your water pumps, fan, intake, distributor. 49-53 will work, mostly fan issues and rad hose hookup. It all depends how much work your willing to do and what outcome you want. Stock,custom,high performance, it's up to you. |
10-17-2019, 08:35 AM | #3 |
Any 59a block would be a good fit, but so would other years.
10-17-2019, 08:52 AM | #4 |
looking for simple and stock.
looks like most will fit? how about truck engines or 60 hp? |
10-17-2019, 10:03 AM | #5 | |
Are you looking for a complete engine that is a bolt in? A short block that will work? A bare block to build up? The original engine was most likely what is referred to as a "raised" intake surface block. There are very few years with that feature, mainly 41. When you get into the V8-60 and the 6-cyl engines I think you would have transmission/bellhousing issues, maybe radiator issues. Last edited by JSeery; 10-17-2019 at 10:13 AM. |
10-20-2019, 02:59 PM | #6 | |
yep the V8 bell is different than the 6 |
10-17-2019, 09:01 AM | #7 |
ronn:
Suggest you do a lot more research about the differences between the various flat head Ford engines BEFORE you do anything else. For instance: Installing a 60 HP engine would greatly under power your 41 and be a huge mistake. |
10-17-2019, 09:46 AM | #8 |
You said "flathead and didn't specify how many cylinders. There are a lot of people who consider the "G" and "H" 6 cylinder engines to be superior to the V8's. Since the first 6 came in '41, they are also a possibility. Parts are more difficult to come by than the more popular V* models, however.
10-17-2019, 04:58 PM | #9 |
Yes J, looking for a complete engine to just bolt in. so will stay away from the 60s and 6 cylinder then.
thank you all. |
10-17-2019, 05:06 PM | #10 |
I would think any of the 59a engines (46-48) would be a fairly simple install. A 41 or war year engine would be a good option but probably not many of them out there.
Does anyone know what the oil pan variations are between the 41 cars and the later 59a car and/or pickup-truck engines? |
10-18-2019, 12:36 PM | #11 |
PM sent
10-18-2019, 09:45 PM | #12 |
I believe 3 engines were available for 1941, 4, 6, and v8.
Only year as far as I know. Bruce
Works good Lasts long time |
10-20-2019, 07:38 AM | #13 |
ok and how about a 1934?
I have a lead on a couple that I can drive to. |
10-20-2019, 07:55 AM | #14 |
10-20-2019, 09:43 AM | #15 |
10-20-2019, 08:00 AM | #16 |
did not Tom- where is it listed?
thanks |
10-20-2019, 07:46 PM | #17 |
10-20-2019, 11:15 AM | #18 |
yes and simply why?
10-20-2019, 01:56 PM | #19 |
They have value as an original engine in the early bodies, but would be a problem in a later body, like a 41. Parts are more difficult to come by, rebuild cost are higher and nothing would really fit correctly (heads, intake manifold, water pumps, motor mounts, distributor, cut-out generator vs voltage regulator, fan location and type, etc). It would take a lot of work/exchanging parts to get one in a 1941 and on top of everything else, it would devalue the 41 as far as resell would go. And it would decrease performance. Can not think of any positives even if the engine was in good condition and free!
10-20-2019, 12:50 PM | #20 |
They are a lot more expensive to rebuild, because of the babbit main bearings and different rod bearings also the water pumps are in the head so, it complicates the installation.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
