05-09-2019, 02:24 PM | #21 |
Re: Front axle restoration
It seems this topic comes up here every once in awhile and even after the discussions it is still confusing to folks. Hopefully this PDF helps us understand the differences.
In my opinion, if you do not have the alignment jigs AND either a correct inclination gauge or a couple of digital protractors, you cannot measure this accurately enough to even bother with it as you can make it worse very easily. The reason the gauge is so important is each time you make a bend on the axle beam, you must reset and re-level so that your calibration is the same.. . . |
05-09-2019, 02:45 PM | #22 |
Is there someone on the East Coast that sells them already straightened and the perch holes correct?
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
05-09-2019, 06:33 PM | #23 | |
05-10-2019, 10:43 AM | #24 |
Thanks Brent, that pdf explains it nicely.
