06-27-2021, 05:49 PM | #1 |
No reverse
I have a 1931 model a Tudor with no reverse all forward gears work. Any help would be appreciated
06-27-2021, 06:33 PM | #2 |
Re: No reverse
More information would be needed to give suggestions on what may be wrong. How long have you had no reverse? Is there any noise? Have you taken the cover off to look inside? Is this car new to you? We can make wild guesses, some of which may be correct some not. What ever the issue is will be inside the transmission, we can not see that, so you need to have a look see.
Or be like the 58 Morris Minor I had with no reverse, had to push it into the parking spaces. Fun parallel parking in downtown Portland!
06-27-2021, 06:40 PM | #3 |
Re: No reverse
There are forks inside the transmission that move the gears inside for first, second, third, and reverse. The reverse gear could be damaged or the shift tower that moves the forks could be damaged.
It is a simple mater to peek inside the transmission by removing the shift tower. Remove the floor boards after removing any carpeting or mats. Put the car in neutral. Remove the bolts holding the sift tower, the part that has the sift lever attached to. Check the shift tower to see if it is shifting into reverse correctly (it should have full range and click into position). There are three shafts in the transmission, the main shaft, the counter shaft on the bottom and a short shaft that holds the reverse gear. Look inside with a flash light or light to see what is not right. It is likely that you will have to rebuild the transmission but look first to see what is wrong. If you are lucky there will be something blocking the shift tower from completely moving into reverse. Cover the transmission with cardboard so that nothing falls inside. Put the sift tower back into neutral before re-installing. Use a new gasket and clean the mating surfaces. Make sure the two forks engage the two collars inside the transmission.
06-27-2021, 07:34 PM | #4 |
Re: No reverse
Does the car have a Borg Warner overdrive?
Tom Endy |
06-27-2021, 07:54 PM | #5 |
Re: No reverse
Thanks for replying; had the car for about a year and 1/2. It wasn’t running then. I got the engine rebuilt and it seems to run ok. I took the shifter plate off and I can move the reverse/first and second/third clusters back and forth freely. If I have it in reverse the gears turn and the reverse idler also turns. I have a new clutch and throw-out bearing. I drives normal when going forward in all gears.
06-28-2021, 12:04 AM | #6 |
Re: No reverse
06-28-2021, 05:18 AM | #7 |
Re: No reverse
Some of the things that can cause the transmission to not shift correctly are worn forks, the ball at the end of the shifter worn to a square shape, the detent spring broken or weak, the detent grooves worn, and probably others that I don't know about.
As Tom alluded to, if you have the Borg Warner overdrive it can cause problems if you are in overdrive and try to back up. Try posting some photos.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 06-28-2021 at 05:23 AM. |
06-28-2021, 07:16 AM | #8 |
Re: No reverse
Ok you have the top off check the countershaft or sometimes called cluster gear to make sure it is engaged to the reverse idler gear and no teeth are missing, then slide the low\ reverse slider gear back to engage the reverse idler gear. You should have reverse if nothing is broken like missing teeth. If all of the above checks out it can only be the shift tower.
Dale |
06-28-2021, 11:19 AM | #9 |
Re: No reverse
If you have 1st and unless the reverse idler gear is missing or major teeth damage, you should have reverse. They both use the same sliding gear and fork. When the low/reverse sliding gear is slid back it engages the idler gear not the gear on the cluster shaft. I don't think a worn ball would explain it, if you can drive the car in 1st, but could be a bent fork not allowing the low/reverse sliding gear to move back far enough to engage the reverse idler gear. The cluster gears are on the shaft below the sliding gears, and the reverse idler gear is to the left looking down from the rear.
06-28-2021, 11:49 AM | #10 |
Re: No reverse
The reverse idler gear engages the cluster gear so missing teeth there would cause no reverse.
Dale |
06-28-2021, 02:07 PM | #11 |
Re: No reverse
As Tom mentioned earlier, if you have Borg Warner Overdrive and the plunger is pushed in to engage the OD, you will have no reverse gear. Pull the Overdrive plunger out and reverse will work.
07-10-2021, 09:05 AM | #12 |
Re: No reverse
I do not have an overdrive. I removed the shift plate with the transmission in reverse and with the engine running I release the clutch the gears turn as designed. Again all forward gears work and the car moves fine in all gears, once it’s shifted into reverse and release the clutch I feel a slight tension but no movement of the vehicle.
07-10-2021, 09:54 AM | #13 | |
Re: No reverse
www.whidbeymodelaclub.com |
07-10-2021, 11:42 AM | #14 | |
Re: No reverse
07-10-2021, 12:44 PM | #15 |
Re: No reverse
I wonder if maybe an axle is broken in such a way that it will move the car forward but not rearward? Try jacking up the rear tires and pull on them outward, away from the center differential while turning them rearward.
