08-18-2018, 03:27 PM | #1 |
1957 ford
does anyone know the thread size on a power steering drag link end where the control valve screws on. tony
08-18-2018, 08:39 PM | #2 |
Re: 1957 ford
Thread size is 5/16 coarse.
The bolt used is slightly shorter than 1" (but a 1" should be fine) with a 1/2 head , 5/16 coarse thread with a flat star washer. Oldmics |
08-19-2018, 03:35 AM | #3 |
Re: 1957 ford
drag link end has a fine thread 28? tony
08-19-2018, 08:21 AM | #4 |
Re: 1957 ford
You are probably going to have to measure the size if you have a drag link. There is no size info in cataloging.
***** - MULTI-VEHICLE SYNTHETIC TRANSMISSION FLUID - Multi-vehicle transmission fluids are becoming more and more popular in the marketplace. Oil marketers design these fluids for a wide range of automatic transmission types. While they are not licensed by any specific auto manufacturer ... ??? ... enough said ... DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
08-19-2018, 09:05 AM | #5 |
Re: 1957 ford
Lets be sure that I am understanding what you are asking.
The picture below shows the control valve assemble. The bolt on the left side (loosened) that holds the control valve onto the drag link is the 1" 5/16 coarse bolt. The other side (right side) is a 1/4 X 1 1/2 long coarse slotted head screw. Are these the bolts you ask about ? Or are you looking for the larger fine thread bolts that hold the idler arm bracket to the frame ? Oldmics Last edited by Oldmics; 08-19-2018 at 09:19 AM. |
08-19-2018, 10:22 AM | #6 |
Re: 1957 ford
08-19-2018, 01:01 PM | #7 |
Re: 1957 ford
yes the fine threads on the drag link end 1-24 ?or 1-28? will mic and get a thread gage tomorrow
