Old 03-13-2016, 07:21 PM   #1
miff
Default Horn stops working
My horn will turn with no pressure on the diagram. But when I start to adjust it for the sound. ( a click at a time) when it starts to put pressure ( very little )on the diagram the arbor stops turning . With no pressure it spins fast and free. Any ideas , (it's an Ames horn) Miff
miff is offline   Reply With Quote
Old 03-13-2016, 07:35 PM   #2
ericr
ericr's Avatar
Default Re: Horn stops working
have you cleaned the commutator with sandpaper?
ericr is offline   Reply With Quote
Old 03-13-2016, 08:10 PM   #3
heneste
heneste's Avatar
Also, if it hasn't been lightly oiled it may need the two-three drops on the felt pad
heneste is offline   Reply With Quote
Old 03-13-2016, 09:05 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I've cleaned commutators with emery cloth while the armature spins. Between that and a few drops of oil on the felts, the horn blows great.
Old 03-13-2016, 10:40 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Yup a good cleaning, inspection of the brushes, movement of the brushes in the holders, and lubing the front and rear of the shaft are in order.
http://modelabasics.com/horn.htm
Old 03-15-2016, 06:02 PM   #6
miff
I want to thank you all for your suggestion on my horn. I want to thank Mike v Florida fro sending to horn basics by Payl R Modlin. Followed his problems and solutions . The horn works great . Miff
Old 03-16-2016, 10:47 AM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
That's good it's working. Another maintenance area is the bullet connections and clips not clean enough. I also found a brush not in position correctly, yet still partially working.
