07-19-2015, 01:51 PM | #1 |
Throw out bearing hub
I am using a AA bell housing with a new pressure plate from Brattons. Clutch throw out bearing that are new . The problem is the throw out bearing is tight against the clutch fingers . There is no movement at all. I am using A throwout bearing hub out of a standard model a. Have any of you removed metal off the backside of the hub to make it work .If so how much do I need to take off to be safe and it still operates correct. ( looks like to be an eight to one quarter tops) Or need to find aa through out bearing hub. That the case have any of you have a aa hub your willing to part with? Building this speedster has its monents. I thought building the body, coverting the brakes to hydraulic would be the Challenge . That's what I get for thinking. But when it's done it will be one of a kind . Miff
07-19-2015, 01:55 PM | #2 |
Re: Throw out bearing hub
The AA Throwout Bearing Hub is a lot shorter than a standard Model A one.
The return spring is also shorter on the AA. I don't think you can shorten the A hub enough.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
07-19-2015, 01:56 PM | #3 |
The AA hub is shorter. Here is a picture Dan Partain posted.
Bob Last edited by Bob C; 07-19-2015 at 02:04 PM. |
07-19-2015, 02:17 PM | #4 |
Well it looks like I an going to be on a hunt for a aa hub . Thanks Miff
07-19-2015, 02:27 PM | #5 |
Try Steve at Bert's Model A in Denver..1-800-321-1931
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
07-19-2015, 06:29 PM | #6 |
07-19-2015, 07:48 PM | #7 |
Miff Dont mean to hijack your post but would you post some constuction pictures of your boat tail speedster? I am in the earley stages and need to see some new ideas thanks Don in Indiana
07-19-2015, 07:55 PM | #8 |
I would be happy too but I still have trouble with posting pictures. As you can see the it was picture posted was on its side. It was right side up in my phone .
07-19-2015, 07:59 PM | #9 |
Indiana a lover if you will send me an email address on pm I will try that way
