09-14-2018, 10:56 AM | #1 |
What Spider Gear to Use?
I am putting together a 4:11 rear end for our '35. I have 18 tooth rear axles.
Do I use 12 tooth or 11 tooth spiders with those axles? Thanks, Mike |
09-14-2018, 11:10 AM | #2 |
Re: What Spider Gear to Use?
I never counted spider teeth, but if 11 and 12 are the choices, then the 12 would be it. You're not looking for a ratio, just a mating of the teeth.
Alan |
09-14-2018, 12:46 PM | #3 |
I can look it up later, one was early and one was later, but don't remember which is which!
09-14-2018, 12:48 PM | #4 |
12 tooth spiders with 18 tooth axles
09-14-2018, 06:23 PM | #5 | |
16 tooth '39 - '41 The above are interchangeable in sets with appropriate spiders.
Alan |
09-14-2018, 07:34 PM | #6 |
