Old 08-07-2016, 03:56 PM   #1
al's28/33
al's28/33's Avatar
Default Air Cleaner Clamp...won't tighten
I am trying to swap out air cleaners on my '33 but the one I want to use won't clamp tight on the carburetor. No matter how tight I make the screw and nut, it still has a lot of play.
Should I try another clamp ?
The flange around the bottom of the air cleaner is notched into four sections and seems like they should compress when fully clamped....should I cut those spacings larger ?????
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 08-07-2016, 06:05 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Air Cleaner Clamp...won't tighten
Al, apparently, from your information, you've replaced the Model B engine with a V8, but no information on which carburetor setup you have, nor any information on the air cleaner you wish to use. Any responsible answer to your question would require more information from you.
Alan
Old 08-07-2016, 08:37 PM   #3
al's28/33
al's28/33's Avatar
It was a "B" but previous owners installed V8 engine.
I use a Stromberg 94 Carb. Air cleaner now is for a '34.....air cleaner I want to use is more original to the '33 engine compartment but the darned thing won't clamp tightly around the top o the carb.....any ideas ??
Old 08-07-2016, 08:39 PM   #4
al's28/33
al's28/33's Avatar
I wanted to replace this air cleaner with the '33 style pointed dome type air cleaner and it will not clamp tightly
Old 08-07-2016, 09:23 PM   #5
Rustyspokes
Rustyspokes's Avatar
Al. I soldered some brass shim stock all around the inside of the flange on the air cleaner, also used a different clamp with a long handle and a wing nut at the end, it was from a 1950 Ford if I can remember, hope this solves your dilemma , cheers ...Rusty
Rustyspokes is offline   Reply With Quote
Old 08-07-2016, 09:40 PM   #6
fourfords
fourfords's Avatar
I would take the air cleaner you wish to use and tighten it as far as needed OFF the carburetor and observe why it is not compressing. During this process, it is possible that the air cleaner orifice will retain some of its compression and fit better on the carburetor.
fourfords is offline   Reply With Quote
Old 08-07-2016, 10:49 PM   #7
koates
Hi there, Your carb is not a Stromberg 94, looks more like a Stromberg 48 which was fitted to 34 and 35 V8s. I have the small pointed top helmet style air cleaner on my 34 Ford V8 sedan which was correct for AUSTRALIAN 34s. It tightens up on the carb just fine. You need to have a very close look at the way it clamps on. Those air cleaners were purchased by Ford by an outside supplier (a battery company) who made them to fit other makes of cars besides Ford. Measure the diameter of your carb top and also the closed/tightened diameter of the cleaner neck (off the car). Then operate on it if need be. Regards, Kevin.
koates is offline   Reply With Quote
Old 08-08-2016, 12:48 AM   #8
Graeme / New Zealand
Graeme / New Zealand's Avatar
Check the thread on the shaft of the "srewy thing". I had the same problem and found the threads were stripped.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 08-08-2016, 06:45 AM   #9
Jakno
Jakno's Avatar
Al, I have a 1935 pickup with 59AB & Stromberg with the same issue. Please post your solution... Thanks
Lineman, the only dumb animal that can harness himself !!
Jakno is offline   Reply With Quote
Old 08-08-2016, 11:32 AM   #10
Lanny
Lanny's Avatar
Here is an AD in our classifieds for some air cleaner adapters,
maybe one will work for you ?
https://www.fordbarn.com/forum/showth...38#post1335838
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 08-08-2016, 11:58 AM   #11
Willit Stop
Willit Stop's Avatar
A cross section or two of a motorcycle inner tube might work.Use it as a spacer/sleeve around the throat of the carburetor.
Willit Stop is online now   Reply With Quote
Old 08-08-2016, 04:43 PM   #12
Barry-ct
Barry-ct's Avatar
I also made a thick gasket to fit the top of my carb because the clamp would not tighten up all the way. Used the lid from a plastic coffee can and cut to fit. Works perfectly now.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 08-08-2016, 06:34 PM   #13
al's28/33
al's28/33's Avatar
thanks everyone....... I kinda like Rustyspokes advice, I would feel more at ease knowing whatever adapter I used didn't in turn wiggle loose and the whole air cleaner started bouncing around the engine compartment. I will have to tinker and see what I come up with.
Lanny I appreciate the link!!
