01-19-2014, 11:22 PM | #1 |
Help with pop out switch--I lost my key!
I'm kicking myself for having lost the key to my '29 Standard Coupe. I have what I believe to be an original pop out switch. Does anyone know if there is a way to remove the lock cylinder without removing the entire armored cable from the distributor ? Thanks in advance for any advice you may have.
Smurph |
01-19-2014, 11:51 PM | #2 |
Re: Help with pop out switch--I lost my key!
On the edge of the bezel that is around the lock it should contain the lock number A***, 3 or 4 digits. You may have to remove the pop out from the dash cup to see the number.
Another way is to have a Lock Smith decode the lock and make a key for you; of course this would require taking the Pop Out out unless the lock smith could come to your home. If you can come up with the lock number, contact A & L Parts, they can cut keys for you. Ron |
01-20-2014, 08:02 AM | #3 |
Here's a picture showing what Ron just described. Hopefully you can use a magnifying glass to read the number without the cylinder being out (ON position). Be sure to order 2 keys from A&L so you can keep one in a safe location. This is the last phone number I have for A&L 1-860-693-2620.
01-20-2014, 09:45 AM | #4 |
What does it cost these days to have a key made, assuming you only have the lock number?
01-20-2014, 10:11 AM | #5 |
Last call for help?
If you go to "Search" to find his phone number, & if you call Mr. Dick Crabtree for a wealth of Model A pop-out switch restoration & key manufacturing information, it is guaranteed that this will be your LAST CALL. Just try him. |
01-20-2014, 11:26 AM | #6 |
Thanks, Smurph |
01-20-2014, 11:41 AM | #7 |
You probably have the repro popout. I don't think replacement keys are sold for it, but other key blanks (from what I've read here) can be made to work. Do you have a picture of the key slot? That will tell us for sure.
01-20-2014, 11:41 AM | #8 |
You have one of the made in Spain repops. They had key numbers 1 through 9. They are real easy to pick.
01-20-2014, 12:59 PM | #9 | |
Charlie Stephens |
01-20-2014, 02:03 PM | #10 |
Thanks to all for your helpful replies. Attached is a picture with a close up on the tumbler. You can see the #4 on the left side of the key slot. If this a Spanish repop, any ideas where I could get a replacement key?
Thanks again, Smurph |
01-20-2014, 02:05 PM | #11 |
Here's another if of the entire housing. (I couldn't upload two at once!?)
01-20-2014, 02:26 PM | #12 |
There was an article in the Restorer Vol 36 Issue 6 Pages 35-41 on the Electrolock switch. It shows how to remove the tumbler without a key.
Bob |
01-20-2014, 05:41 PM | #13 |
01-20-2014, 05:47 PM | #14 |
My locksmith charges about $15 to make a key to fit a random lock. May be your best bet.
01-20-2014, 06:09 PM | #15 | |
The lock had a number on it so the shop looked it up and cut me two keys and charged me $5.00. I think it was my lucky day. Afordman31 |
01-20-2014, 10:37 PM | #16 |
Both mine are Number 1, hope some one with the #4 key will contact you. That would be too easy though. Bob
01-21-2014, 09:52 AM | #17 |
Contact Brattons as they used to sell spare keys for that popout.
Bratton's Antique Auto Parts, Inc. 1606 Back Acre Circle Mount Airy, MD 21771-7703 Toll FREE Order Number: 1-800-255-1929 Information Number: 1-301-829-9880 |
06-25-2014, 09:20 PM | #18 |
You have a #1 ? I have the #1 also but missing the key. Any way I can arrange with you to get a copy of your key? [email protected]
06-25-2014, 09:57 PM | #19 |
Hey dmarx01,
THE pop out guru is Dick Crabtree in South Dakota. If anyone can help you, Dick can. Call him at 605-487-7229. Good luck, Smurph |
06-26-2014, 12:24 AM | #20 |
Contact Alan at A&L. I am sure he can help you and it will be very reasonable.
Wayne |
