07-12-2021, 06:56 PM | #1 |
Strange head
head 2021 2.jpg 2021 head 5.jpg 20210712_134654.jpg The water openings are much longer on the head in question. No markings on the head except the dimples on the water pump flange. Also no water opening between 2 & 3. Any ideas ?? Gary in MN |
07-12-2021, 07:25 PM | #2 |
Re: Strange head
I think it is an early head as the center waterjacket hole is not punched out. I believe that started in 1929.
"The more things change, the more they stay the same." |
07-13-2021, 06:13 PM | #3 |
Re: Strange head
Where did you get this head? Hi-compression maybe?
07-13-2021, 07:54 PM | #4 |
Re: Strange head
The head does not appear to be high comp. The head was in the pile of parts for a 1931 pickup project. Gary
07-14-2021, 12:24 PM | #5 | |
Re: Strange head
07-14-2021, 01:03 PM | #6 |
Re: Strange head
07-14-2021, 01:26 PM | #7 | |
Re: Strange head
Tbh, I wouldn't recommend using this head for anything since the center cooling hole seems to be missing entirely, which will compromise the ability to cool the head. |
07-14-2021, 01:53 PM | #8 |
Re: Strange head
The block you pictured has the cooling hole, but the heads were solid in that area, until late 29 as I recall. All my books were lost in the fire, so I can't give an exact date.
07-14-2021, 09:48 PM | #9 |
Re: Strange head
The blocks had a hole there but the heads didn't?
07-15-2021, 08:03 AM | #10 |
Re: Strange head
I suspect that the absence of the water passage between Cylinders 2 & 3 improves the coolant flow around Cylinders 3 & 4. That is, the water pumps intake suction becomes greater at the back end of the head.
Bob Bidonde |
07-15-2021, 10:32 AM | #11 |
Re: Strange head
The hole in the block may have been to facilitate removing sand after the block was cast, not for cooling.
