03-13-2019, 12:09 AM | #1 |
Ford Model A Klaxon horn
Would anybody know anything about or the make of this Model A klaxon horn.
03-13-2019, 12:57 AM | #2 |
Re: Ford Model A Klaxon horn
G'day Ian
That horn appears to be a modern era repro horn, not Model A horn. It may be 12v. The horn on your '32 will be the same as the A, except for the motor cover. Cheers Tom in NZ. |
03-13-2019, 01:16 AM | #3 |
Hi Tom & Ian,
They were very common here in the 70's and cost approximately $20. They were made by Hutchins. I have an original '32 sparton motor cover, if you need one Ian.
1928 Roadster (CA67) 1931 Deluxe Coupe RHD 1931 Victoria RHD Model A's don't leak oil they just mark their territory. |
03-13-2019, 02:07 AM | #4 |
Hi Tom & Bick Thanks for the information. I have just now bought a original Model A Sparton horn on Trade me as the one on the 32 sounds a bit sick. the trouble is a lot of these horns have originally been run on 12 volts which does not help them.so I want to and replace it with another one with improvements. That Hutchins horn has just came up for sale on Trademe.
03-13-2019, 04:56 AM | #5 |
love your signature Bick. I quote it from time to time. today I scored some discarded carpet I need to place under Woofa Express. the person discarding it asked what I'd want it for and I quoted your signature. cheers, gary
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
03-13-2019, 01:36 PM | #6 | |
03-13-2019, 07:17 AM | #7 |
In depth discussion of Hutchins horns. Including the fact that in 2016 they were still available new and the owner of the company posted here.
https://www.fordbarn.com/forum/showthread.php?p=1286438 Joe K
Shudda kept the horse. |
03-13-2019, 01:40 PM | #8 |
Ian, I just had a thought that the base plate on the '32 Sparton is different to the Model A, to accommodate the '32 cover. Someone with more knowledge of this will hopefully chime in with the facts.
03-13-2019, 04:24 PM | #9 |
The 1932 cover fits straight on but base plate which takes the 32 mounting bracket is different so the six holes with the bolts that clamp everything together have to be rearranged thats what I had to do to the Model A Sparton horn I have on the 32.
