Old 11-06-2019, 11:12 PM   #1
daveymc29
daveymc29's Avatar
Default Stop Quick, engine dies
Friend called today with the above. I'm sure it has been addressed several times and hope I gave him the correct answer. I told him to lower the fuel level in the float bowl to not higher than specs. If that is correct let me know. That is how I remember it when I had the same trouble, but I didn't find a thread.
daveymc29 is offline   Reply With Quote
Old 11-07-2019, 01:33 AM   #2
Synchro909
Synchro909's Avatar
Default Re: Stop Quick, engine dies
David, I would have given him the same advice.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 11-07-2019, 08:29 AM   #3
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
First and easiest thing to do is flatten the surfaces between the carb flange and intake manifold flange. I'm sure you will find them warped a bit. I have fixed several doing just this. All you need is a big file, a light and mirror and a new gasket.
Jacksonlll is offline   Reply With Quote
Old 11-07-2019, 09:49 AM   #4
Mulletwagon
Mulletwagon's Avatar
Had the same problem despite proper fuel level. Fixed problem by blowing out the idle passage and jet with carb cleaner. The passage goes from the idle jet in the bowl, up the top half of the carb, and exits right at the throttle plate. Also important to adjust the idle mixture properly. Set idle speed to minimum, retard spark, and turn idle mixture screw for best idle. Usually setting the idle speed higher to avoid stalling does not work since the high speed jet kicks in and the reduced vacuum at the idle port is too low to pull fuel.
Mulletwagon is offline   Reply With Quote
Old 11-08-2019, 07:50 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
When stopping quickly, the gasoline in the float bowl surges forward uncovering the passage to the Compensator Jet, and uncovering the passage to the Main Jet & GAV. It is likely that the Idle Jet Well retains some gasoline, but the Cap Jet and Main Jet will starve causing the engine to run roughly / stall.
To remedy the uncovering of the passages to the Compensator and Main Jet, the gasoline level in the float bowl should be increased.
Bob Bidonde
Old 11-08-2019, 08:05 AM   #6
History
History's Avatar
Nice diagram Bob, thanks for posting that.
History is offline   Reply With Quote
Old 11-08-2019, 08:12 AM   #7
30 Closed Cab PU
Here is a link
https://www.modela.org/engine_dies_stop.html
30 Closed Cab PU is offline   Reply With Quote
Old 11-08-2019, 08:36 AM   #8
History
History's Avatar
My brother was telling me yesterday about a 135 Massey ferguson tractor he has that is gasoline powered. He rebuilt the carburetor and like on a zenith thought he had a leak and over tightened the drain plug and cracked the bottom of the carb. He was helping an old fellow who bought salvaged material and junk equipment and he was junking something that had the same carburetor on it. He was able to get it and used the bottom on his. He said the Venturi was smaller and the tractor ran the best it ever had. Are there any problems with the zenith carburetors having adifferent sized Venturi? Do they wear and the throats gets Larger?
When I rebuilt mine I got an original Venturi from Renners corner that had been blasted to clean it, can't remember what was used for the media. I also ordered a new one from Snyders and there were differences that I can't recall but were noticeable. I didn't mic the inside diameter.
Old 11-08-2019, 11:20 AM   #9
jquinlan
jquinlan's Avatar
Before you do anything, open the Gav up and experiment. Myself AND another friend of mine had the same problem with our cars recently which went away after opening up the GAV a half to a full turn more.
Jim
jquinlan is offline   Reply With Quote
Old 11-08-2019, 11:49 AM   #10
PalAl
PalAl's Avatar
Bob, very well explained and a great diagram showing what happens. Thank you
PalAl is offline   Reply With Quote
