12-05-2013, 08:40 PM | #21 |
Re: Ford VICTORIA 1952
I need an adapter for 3 speed trans in order to install a 351W.
can anyone tell me where to get one? |
12-05-2013, 08:44 PM | #22 |
Re: Ford V8-60
No doubt you'll find that info if you google H.A.M.B. They'll have the info you need!!
Lonnie |
12-05-2013, 08:59 PM | #23 |
Re: Ford V8-60
I'm getting ready to pull the tin sided V8 60 out of my '37. Too bad because the car is original except for '39 brakes but every time I come up the hill to our house I feel like I'm churning butter with all the shifts back and forth between second and third. Tough on the trans when it's one of the early straight tooth gear boxes. Engine is in excellent shape and will be available with the trans after the swap.
Henry made a mistake putting this engine in full size cars. Might work better in stripped down model A. Good luck with it. |
12-05-2013, 11:20 PM | #24 | |
Re: Ford V8-60
100 hp is fairly easy with a model A also. Both are quite expensive at this level though. While a model A would be hard to get one hp per cubic inch out of a flathead, it has been done many times with a 60. I would far and away rather drive the 60 though because of no vibration. You would need a 5 or 6 speed behind either one to really enjoy them on the street. As someone already mentioned, talk to Rich Willim about the 60. |
12-06-2013, 07:48 AM | #25 | |
Re: Ford V8-60
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
10-09-2014, 08:19 PM | #26 |
Re: Ford V8-60
10-09-2014, 08:38 PM | #27 |
Re: Ford V8-60
Might get a better response on the HAMB. The Ford Barn is geared more toward stock and slightly modified cars and stock and modified flatheads. The HAMB is more all out hot rods, although they also have a cut off in the 60s and the 351W would be past that time period. I have nothing personal against the 351Ws as I have two of them, one in a 2005 Focus and one in my 70 Truck, but it is not the focus of this site. Wilcox makes a lot of adapters might try them. One suggestion, why keep the 52 transmission, with a 351W engine I would be looking at a later Ford transmission like a 4-speed or a T5 with an overdrive.
10-09-2014, 08:46 PM | #28 | |
Re: Ford V8-60
A gear drive starter is recommended. If you put a Simca V8 flathead crank in the 60 and bore to .100, you can have 166 ci. |
10-09-2014, 08:53 PM | #29 |
Re: Ford V8-60
You guys guys know this post is from last December right?
Lonnie |
10-09-2014, 09:10 PM | #30 |
Re: Ford V8-60
10-09-2014, 09:48 PM | #31 |
Re: Ford V8-60
10-10-2014, 08:09 PM | #32 |
Re: Ford V8-60
Thanks for the advice on my V-8 60 project. It really helps!
Don Hanson |
01-24-2015, 11:20 AM | #33 |
Re: Ford V8-60
Hey Pete I agree with you "WHO CARES"? I am owner of V-8 60 and think I would like it in one of my As . So still reading all available info from anywhere!
My engine was used to run a saw mill in East Texas, My Transmission came from Arizona hoping it is the later one, think it came out of a 41? I will accept all the information I can get.and "Who Cares" was the name of a Drive In Restaurant in Dallas Texas in the 50's |
01-24-2015, 02:40 PM | #34 | |
Re: Ford V8-60
contrary to what people that have never done it say. |
01-25-2015, 06:30 AM | #35 |
Re: Ford V8-60
Here is a 1937 Ford Tudor with the V8 60 that has been imported to Australia |
01-25-2015, 10:19 PM | #36 |
Re: Ford V8-60
Back in the 80s early 90s I had a 29 pickup that had a V8-60 in it. I thought it was a great combo for a model A and it fit good. Id love to build another.
09-13-2018, 02:17 PM | #37 |
Re: Ford V8-60
Hi All, if this post is still relevant; I have a 1952 MGTD with a 1938’ish V8-60, running through a Ford Clutch to a stock MG trans. Took some work to get it going properly after it’s 40+ year slumber but we are running. Love to get some advice. Thanks, Scott
09-13-2018, 05:34 PM | #38 |
Re: Ford V8-60
First piece of advice is, take it REAL easy on that transmission.
09-13-2018, 05:34 PM | #39 |
Re: Ford V8-60
Sure it's still relevant! Can't remember his name, but there's another Fordbarner on here with a v8-60 in an MG, and it is nicely done, too. Maybe he'll see this and chime-in. DD
09-13-2018, 09:06 PM | #40 |
Re: Ford V8-60
Thanks DD; thanks for that, there can’t be more than a handful of them left! Scott
