03-08-2017, 09:37 AM | #1 |
Steering column question
shouldn't the lower bearing housing be flush?
03-08-2017, 09:53 AM | #2 |
Re: Steering column question
http://www.snydersantiqueauto.com/Co...link--3688.pdf
also how does part 34Light rob felt seal go on? The seal I have only has like a .125" dia. hole in it? |
03-08-2017, 12:22 PM | #3 |
ok So I got the column together and in I have not put the pitman arm on the sector shaft yet but I slide the steering wheel on and its very hard to turn. Any idea of what I have done wrong?
03-08-2017, 12:31 PM | #4 |
Do you have the square brass shims in the end plate? You may have to add a few to give it more clearance. You want the clearance to just be at zero without binding the bearings.
03-08-2017, 01:02 PM | #5 |
