Old 03-10-2018, 03:31 PM   #1
BillEbob
BillEbob's Avatar
Default What's required to convert 12v CB to 6v
What piece of equipment must I purchase to be able to use a 12 volt CB radio in my 6 volt positive ground Vicky?
Thanks!
Bill
BillEbob is offline   Reply With Quote
Old 03-10-2018, 05:51 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: What's required to convert 12v CB to 6v
Something like this:
https://www.brattons.com/six-to-twel...r-2-5-amp.html
Check the maximum amps, though.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 03-10-2018, 05:58 PM   #3
KGBnut
KGBnut's Avatar
I got mine on eBay. You may find that they work better with an alternator than a generator, but should work okay with either.
Click Here for Step Up Power Supply Converter Regulator Module
Good luck,
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 03-10-2018, 06:34 PM   #4
BillEbob
BillEbob's Avatar
Thanks guys!
Bill
Old 03-10-2018, 06:41 PM   #5
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Be careful of the low cost ones. When you ground the antenna, it messes things up.
Jacksonlll is offline   Reply With Quote
Old 03-10-2018, 07:19 PM   #6
Tom Endy
Tom Endy's Avatar
This is how I provide a 12-volt negative ground in my 6-volt positive ground Victoria. I don't run a CB radio, but there is enough power to do so. I use it to power a GPS, a back-up camera, and charge a cell phone.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 03-10-2018, 10:42 PM   #7
Ted Duke
Smile Re: What's required to convert 12v CB to 6v
Good luck,
Ken
Ken,
How does it handle the positive to negative switch or is that necessary? I am not a master electrician, but I can plug in the toaster.
Ted
Ted Duke is offline   Reply With Quote
Old 03-10-2018, 11:53 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by Ted Duke View Post
Ken,
Ted
You need to determine if the case of the radio is connected to the neg of the radios power cord. If it is, you either have to change the ground of the car to neg ground or isolate the radio case and the mounting from the car.
Old 03-11-2018, 11:10 AM   #9
Jacksonlll
Jacksonlll's Avatar
Tom Endy's way is the way to go. Our club members use the same thing and there is no issue. Tom, what do you use for a screen with your back-up camera, and where is it mounted?
Old 03-11-2018, 12:42 PM   #10
Tom Endy
Tom Endy's Avatar
Back up camera. See attached.
Tom Endy
Old 03-11-2018, 04:54 PM   #11
barkleydave
barkleydave's Avatar
Not any CB radios used anymore most tours using F.S.R. handheld radios
barkleydave is offline   Reply With Quote
Old 03-11-2018, 05:05 PM   #12
KGBnut
KGBnut's Avatar
Ted,
Mine has two wires coming out of it that are color-coded for Positive and Negative. You just wire it in as it should be.
As Mike said, you need to check to see if your CB is case-grounded. Most of them are. If so, you need to be absolutely sure that it is insulated and there is no risk that you are going to bump something metal against both the CB and the body at the same time. If you are electronics savvy, you may be able to open the CB and disconnect the case ground.
Ken
Old 03-11-2018, 05:08 PM   #13
eagle
eagle's Avatar
For a CB you need to have the chassis at ground. Make sure your converter maintains chassis ground. If you try to float the antenna ground your range will be reduced to hollering distance.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 03-11-2018, 10:03 PM   #14
Ted Duke
Ted,
Ken
Ken,
Thanks, I don't CB anymore, that was in another lifetime. I gave it up when the trucker's started using the f word and the hookers were calling for customers at the truck stops. I will want to charge my cell phone and maybe something small like that.
Ted
Old 03-11-2018, 10:04 PM   #15
Ted Duke
Oh, I gave it up because I had two very young daughters at the time, early 80's.
