Old 10-14-2012, 12:17 PM   #1
Ray64
Ray64's Avatar
Default Tool Size?
Can someone tell me what size tool i can buy to take the main bearing square nuts off? (socket) I have a bad center main shot. Thanks RAY
Ray64 is offline   Reply With Quote
Old 10-14-2012, 12:36 PM   #2
lindy williams
Default Re: Tool Size?
the square heads of the front and center main bearing bolts are 9/16". You need a 9/16 eight point socket wrench.
lindy williams is offline   Reply With Quote
Old 10-14-2012, 12:38 PM   #3
brum1
brum1's Avatar
I used an 11/16" 6 pt. impact socket
"no one knows more than everyone"
brum1 is offline   Reply With Quote
Old 10-14-2012, 12:54 PM   #4
Jim Brierley
I just hold the bolt and unscrew the nut, which is 3/4". This is easier, and more critical when tightening the mains as tightening the bolt has a lot of friction so you don't get a true torque measurement or feel.
Old 10-14-2012, 02:26 PM   #5
Gary WA
Gary WA's Avatar
21/32" Is the proper size. As others say they work with other sizes..
www.whidbeymodelaclub.com
Old 10-14-2012, 03:29 PM   #6
Dave in MN
Dave in MN's Avatar
Lindy has it correct. 9/16" 8 point socket is best. 9/16" open end wrench will also work.
Dave in MN is offline   Reply With Quote
Old 10-14-2012, 03:39 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
There is a "special" tool, many times it can be found in the 1$ box under the table at fleamarkets.
Also there is a small point on one of the corners of the square, it is so you know the location of cotter hole at the other end.
Old 10-14-2012, 06:58 PM   #8
Ray64
Ray64's Avatar
Thanks guys Appreciate it
Old 10-14-2012, 07:15 PM   #9
James Rogers
James Rogers's Avatar
21/32 is for the rods.
James Rogers is offline   Reply With Quote
Old 10-14-2012, 10:31 PM   #10
Gary WA
Gary WA's Avatar
Correct my error!!!
Old 10-15-2012, 12:37 PM   #11
Harold frm Sebastopol
Harold frm Sebastopol's Avatar
Location: Sebastopol, CA (Sonoma Co.-Home of Sonoma Model A's)...Come see Snoopy, Luther Burbank, Taste wine/
Kurt in NJ
For the Flea Mkt. tool, what is the socket configuration & size: Square, 6-pt, 8-pt?
9/16, 21/32, 11/16, other? Both ends the same?
Harold Parizek
Harold frm Sebastopol is offline   Reply With Quote
Old 10-15-2012, 05:13 PM   #12
James Rogers
Originally Posted by Harold frm Sebastopol View Post
Kurt in NJ
Harold Parizek
9/16 eight point. I get mine at Sears.
