Old 01-12-2018, 11:00 PM   #1
classicmuscle
classicmuscle's Avatar
Default 1925 Model T
Looking to buy a "peddler" truck, has no engine, pedals are there, throttle lever and spark advance are cut under hood, has wood cab and wood covered box ( not original). Has radiator, gas tank, steering column (no wheel), has coils and coil box, fenders, running boards and tool box on board. Has a brass fire extinguisher, five tires and rims, cab only has one entrance on curb side and a spare mounted on driver side of cab. Title is m.i.a. will go to secretary of state before completing purchase. Sheet metal is solid except for one fender. Any thoughts on value of this truck, realize it's tough without pictures, any help appreciated.
classicmuscle is offline   Reply With Quote
Old 01-12-2018, 11:30 PM   #2
J Franklin
J Franklin's Avatar
Default Re: 1925 Model T
Offer $800.
Old 01-13-2018, 10:11 AM   #3
fordwife
Since the engine and trans are a unit, how can the engine be missing and the pedals still be there?
fordwife is offline   Reply With Quote
Old 01-13-2018, 10:58 AM   #4
redmodelt
redmodelt's Avatar
Pan would still be mounted in the frame, it would hold the front radius rod in place and the hogs head could be installed giving two extra bolts to hold the rear axle up. The block does not have to be installed to mount the hogs head. Leaving the pan in place was done often enough when making the T frame into a trailer.
I am not sure how you are going to get a title without a block, the serial/vin number is on the block unless at some point the rig was re-titled and a new number was assigned and has it stamped someplace else on the rig.
Old 01-13-2018, 03:00 PM   #5
classicmuscle
Thanks for reply's, yes the pan is still in it. Current owner has a plan to get a title, he just got one for another truck last month, we meet at Secretary of State Monday. Cab has a metal plate on inside of cab just to right of coil box but could not make out what was printed or stamped on it in the storage unit.
Old 01-13-2018, 07:03 PM   #6
nhusa
nhusa's Avatar
Strangest post I have seen on the forum.
Much of it doesn’t make sense.
I think we need more info
nhusa is offline   Reply With Quote
Old 01-13-2018, 07:30 PM   #7
41panelmark
41panelmark's Avatar
I agree, the vin number on most T's is on the engine block however some had it stamped on the frame rail on the left side sometimes under the body portion if I recall correctly.
Photos?????
41panelmark is offline   Reply With Quote
Old 01-13-2018, 10:06 PM   #8
classicmuscle
Old 01-13-2018, 10:17 PM   #9
redmodelt
redmodelt's Avatar
I don't see anything strange about the question.
Old 01-13-2018, 10:34 PM   #10
classicmuscle
Must admit do not know much about model T's but I didn't understand the "strange" comment. Oldest vehicle I own currently is is a '51 F1.
Old 01-14-2018, 01:00 AM   #11
redmodelt
redmodelt's Avatar
By the way, this would be a standard car type chassis made between 1921 and 1925 with the added aftermarket or shop built body. This link from the Model T Ford Club of America should help date it;
http://www.mtfca.com/discus/messages/29/7835.html
Old 01-14-2018, 09:38 AM   #12
classicmuscle
Thanks for info on the earlier/late models, finding these early cars very interesting with the different changes made during production.
Old 01-14-2018, 11:50 AM   #13
classicmuscle
The hogshead in the truck is rusted thru, would a guy buy this separate from an engine/trans.?
Old 01-14-2018, 12:08 PM   #14
Jack Innes
Jack Innes's Avatar
The "hogs head" is heavy cast iron & not likely to rust through. You may be seeing the pan rusted through.
You would be best to find a complete engine/transmission unit - hopefully running for this truck.
Something very odd is going on under the hood - could you post pictures of the pan which seems to be mounted upside down & held together by C clamps?
Jack Innes, Brooklin, Ontario
Jack Innes is offline   Reply With Quote
Old 01-14-2018, 03:34 PM   #15
redmodelt
redmodelt's Avatar
Optical illusion, the pan looks correct to me.
Old 01-14-2018, 04:04 PM   #16
classicmuscle
Pictures posted are only ones I have, they was something in bottom of hoghead that was rusted thru, the bottom of hogshead was tied to front axle rods.
Old 01-14-2018, 05:18 PM   #17
pj's junkers
Send a message via Yahoo to pj's junkers
All I see is the pan and no Hog's Head. Maybe I'm missing something.
pj's junkers is offline   Reply With Quote
Old 01-14-2018, 06:31 PM   #18
Jack Innes
Jack Innes's Avatar
You are correct. If you blow the picture up it makes more sense. The clamp may be holding the inspection cover in place.
The rusted area would be the pan under the missing hogs head.
Old 01-14-2018, 07:13 PM   #19
modelAsteve
modelAsteve's Avatar
Looks like an interesting vehicle- is very heavy- oak weighs a lot!
modelAsteve is offline   Reply With Quote
Old 01-14-2018, 08:23 PM   #20
classicmuscle
Thanks for info, so that is just the pan, like I said appreciate any info. Will probably take heavy wood box off, when I stood on running board the whole truck tipped. Guy has owned it since 1978 and said he duplicated what was there before. Would like to make it look like a tanker or put open bed with boxes on side. Is it worth putting back together, wants $1,500 ?
