05-23-2019, 10:11 AM | #1 |
Searching the name of an axis-component
Hi, can someone please tell me what this assembly is called? I do not find it in the catalogs of bratton's and MAC's.
The ball joint can be moved vertically up and down and it rattles. The shell-shaped cover flange was filled with sealing compound. I think that is not right. Thank you for help!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
05-23-2019, 10:15 AM | #2 |
Re: Searching the name of an axis-component
Looks like the rubber radius rod socket---- originally metal with tension springs
05-23-2019, 10:22 AM | #3 |
The rubber ball is a temporary fix and should be removed, but here is the link for it:
https://www.brattons.com/replacement...ement-set.html Here is what should be correctly installed: https://www.brattons.com/original-st...ocket-set.html Here is a new radius ball, if you cut the old one off and weld this one on. There are articles on how to do that correctly: https://www.brattons.com/radius-rod-repair-ball.html
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
05-23-2019, 10:22 AM | #4 |
05-23-2019, 10:25 AM | #5 |
Here is a link to the rubber ball at Brattons. https://www.brattons.com/radius-rod-rubber-ball.html
I prefer the original type pictured. Bob |
05-23-2019, 11:24 AM | #6 |
05-23-2019, 03:43 PM | #7 |
Guten Abend, many thanks you for the many and fast assistance. Now I know. I found the catalog parts and order the original version from MAC's. Thank you again in the friendly society!
05-23-2019, 03:51 PM | #8 | |
Do understand that the ball is supposed to be 1.500" in diameter. When the radius rod ball is worn, mechanics used to put the rubber ball onto the metal ball to take up the clearance difference. Purchasing the correct kit may not be the correct thing to do unless the ball is restored to correct specs. |
05-23-2019, 03:59 PM | #9 |
Brent, and what should I order better then?
05-23-2019, 06:34 PM | #10 |
I just repaired one of those. I made a guage with a 1.5" diameter hole in it, then built up the worn part of the ball with weld. I used an arc welder and fed in some extra metal as I welded to build it up. I then spent some time shaping it so that my guage just fit over it in all possible directions. If you take this course of action, make sure you buy the correct socket for the ball - not one made for the rubber ball. They are different sizes.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 06-03-2019 at 07:26 PM. |
05-23-2019, 06:42 PM | #11 |
Werner this kit will shim the wishbone ball for a good fit with the correct parts.
https://snydersantiqueauto.com/Produ...earchByKeyword John
Welcome each day |
05-23-2019, 06:53 PM | #12 | |
05-23-2019, 07:02 PM | #13 | |
John, I don't want to start an argument but Model-T radius rod ball and a Model-A ball are two different sizes. And most people who have tried shimming have found the results as dismal at best. The problem is the ball is not worn to a smaller diameter, -it is worn flat. |
05-23-2019, 07:17 PM | #14 |
Restore the ball, -then order the correct type system. Many people do not realize how critical the fit of that is for two reasons. The first is steering. When the radius rod ball has clearance to move, it changes caster on bumps, and when one side hits even the smallest of obstacles, it allows the front axle to move in a lateral rotation which affects the steering drag link location. This can cause the car to dart when hitting a bump in the road or a R/R crossing. The second issue when the ball can move vertically happens when the brakes are applied. When the brake pedal is depressed and the brake rod is pulled, the shoes begin to scrub against the drum which causes the entire axle assembly to rotate forward. As this rotating happens, the front brake levers get pulled even more applying much more brake pressure -however this action is not controlled o because of the over-braking the driver releases some pedal pressure which allows the front radius rod to relax and fall back downward releasing more pulling pressure on the brake levers than the driver intended. Add this nonsense to the handling issues in the loose steering, and the car behaves like a worn out-old farm tractor going down the road. |
05-24-2019, 03:51 PM | #15 |
Yes, that describes very accurately the symptoms that my car has: Very bad straight run, on bad roads downhill, plucking brakes unevenly.
Unfortunately, brattons do not currently have the complete O-repair kit available, so I had to order the replacement with a rubber cap. Thanks to all for the helping information!
05-24-2019, 06:50 PM | #16 |
I would have then tried Snyder's or Bert's for the original style kit.
When I removed the rubber ball kit from my 1928 and installed the correct style kit, the ball wasn't worn enough to need any fixing. The plates still had at least 1/8" gap between them, so they held the ball firmly in place. |
05-25-2019, 11:05 AM | #17 |
Apparently I'm just missing the sleeves and springs. The lower plate is cocked - I knew something wasn't right. Haven't driven it enough to notice handling issues. Will gauge the ball when I get it apart.
05-26-2019, 05:59 PM | #18 |
Bert’s has the correct kit and the ball in stock.
05-27-2019, 09:13 AM | #19 | |
John
Welcome each day |
06-03-2019, 06:47 AM | #20 |
Guten Tag Tom, I have now received the original replica and the pan dish from Don Snyder. Something irritated me the very thick (grease?) felt.
Where does he have to go? Thanks again!
