04-09-2012, 01:20 PM | #1 |
Flat top VS domed pistons for HP
I'm building a 221 for my 36 PU. If you have the corresponding correct heads, and have the same static compression ratio when assembled, will domed pistons make more HP in otherwise identical engines? I haven't seen this discussed. As far as I can tell, the difference between a 85 HP engine and a 90 HP engine are the pistons and heads, and maybe the ignition curve in the distributor. If it doesn't, why did Ford make the change? Which one would make more turbulence in the chamber?
I already have a set of .100 over flat top pistons, but I can get a set of replacement heads for 36 waterpumps that have domed chambers, and I thought that if there is a significant advantage I should use the domed heads and get another set of pistons. I'm using an L-100 cam, might go to Don Orosco's Eddie Meyer heads which can be had either way. Opinions? |
04-09-2012, 03:34 PM | #2 |
Re: Flat top VS domed pistons for HP
I can strongly recommend that you get the heads cc'd by a reliable machinist so that you'll know what you are working with, domed or not. Here is a thread that may help you in the variety of 21-stud heads that I encountered in my 36LB motor rebuild:
https://www.fordbarn.com/forum/showthread.php?t=42266 I have a set of the Don Orosco heads, and he will provide them to you either way, that is correct. As of this past summer, however, he was troubled by bad castings and didn't have any available in either configuration. Don't know if he ever got good castings from the foundry and finished up my his machinist. But from my research, the configuration boiled down to a personal preference. Opinions were strong for both camps. Take your pick. Pete Richmond, VA |
04-09-2012, 04:45 PM | #3 |
I have several sets of heads, I've CC'd them myself and they match up with what they are supposed to measure per the casting numbers. I only have cast iron heads, if I want 8-1 CR I'll have to mill something heavily or get the Don Orosco heads. The flattops should be easier to deal with because I won't have to recut the chamber domes.
04-09-2012, 06:34 PM | #4 |
i would not boar a 36 221 eng .100 over the walls on these engs are not as thick as the 37 up engs your going to need a radator from a peterbuilt truck.
04-09-2012, 06:44 PM | #5 | |
But I just got a call from the polisher that the ribs on my Don Orosco repops are now bright and shiny, and I can come pick them up at his shop. Decisions, decisions. |
04-09-2012, 06:45 PM | #6 |
On the things you mention, I would choose domed chambers and if using the helmet distributo use the '37-41 type with 1941 11A stamped advance mechanism. |
04-09-2012, 08:50 PM | #7 |
I'm using a 37 block, but thanks for the warning.
I have 37-41 guts in my 36 distributor, but I don't have the 11A advance. How important is that? |
04-09-2012, 08:55 PM | #8 |
It is a quicker and longer curve that should give a little extra pep. Rear of shaft will have the 11. Helmet distributor cores are dirt cheap, and few people charge more for the '41 or even know that it's different, a development of Ford noticing gas getting a bit better. It can be pretty close to a free upgrade.
04-10-2012, 07:27 AM | #9 |
Don't you just love these little 21-stud motors? I'm nuts about them, but many people aren't fans. My buddies call it, "A more expensive way to go slower...." That's pretty funny, and maybe just a little true. Good luck with your motor.
Pete |
04-10-2012, 09:09 AM | #10 |
Thanks guys. This is going in a real original 36 pickup and I don't want to change motors, plus I think the 21 studs are neat now that I know a little about them. The truck was certified HPOF at Hershey, then the babbitt went out. I'm plotting how I can put the grease and dirt back on after I reinstall the engine...
Anyone have pressure test plates for a 21 stud? |
04-10-2012, 09:19 AM | #11 |
Oddly, I have never actually lined up a 24 stud head and a 21 stud one...I'm sure lots of people here have and can comment.
I believe that all the stud holes will be in same place except for the bottom row so that if you drill the holes for the studs that are at the lower/outer edge of each cylinder, 24 stud test plates would go on, and at most you might have to thread and plug any of the paired 24 stud lower holes that overlap with a water hole...if no one on here has actually matched up heads to see, unlikely, I think I can find one of each tonight and see. |
