12-25-2012, 07:04 AM | #1 |
Looking for a cheap fix, (Pistons)
I aquired an engine with a .040 overbore that needed valve work. Cool! decided to change rings and plastigauge the journals. More a refreshment than a rebuild. So far everything's look good except for one piston's wrist pin. It's loose and sloppy, clearly needs replacing. Also, I don't like the pistons, too low a deck height. Things aren't right with them. So I want to get a new set of pistons and rods. Unless the wrist pins are all a standard dia. and I can just change them. This is kind of a dilema, do I have to change the rods too and refit the rod bearings? Or can I just rebush the wristpins and use the old rods? How standard are they, how much variation is there in the wrist pin diameters? Thanks in advance.
Terry |
12-25-2012, 07:12 AM | #2 |
Re: Looking for a cheap fix, (Pistons)
If the wrist pin is loose in the piston,just replace the pistons. If the wrist pin is loose in the rod, you have 2 choices. One you can replace the rods or, you can replace the bushing in the one rod and hone it to fit. If the pin is loose in both, I would replace both rods and pistons. To replace the bushing, you could send the one rod to me and I can install a new one and fit it to the pin.
12-25-2012, 09:06 AM | #3 |
Sorry for the double post! Thanks for the offer, James. It is appreciated. However I have two presses that will be adequate. I'll make an installation tool, mandel, plug etc and a brass hone. I will use my drill press to turn the hone. This should be adequate for a one time deal. Thanks again! Oh Yeah, You wouldn't have an old set of .040 pistons that are good would you? I really don't like these.
Terry Last edited by Terry, NJ; 12-25-2012 at 09:12 AM. |
12-25-2012, 10:53 AM | #4 |
I'll look later today
12-25-2012, 02:58 PM | #5 | |
See my reply to your other post. Joe
1929 Tudor since 1962 Feather River A's |
12-26-2012, 12:16 AM | #6 |
